How to use neural compute stick2 run my own caffe model?
Shaw__Louis
I think the only modification I should do is on my preprocess part.Here are my preprocess part code:
def TransmissionEstimate(im_path, height, width):
    caffe.set_mode_cpu()
    #net = caffe.Net('DehazeNet-new122.prototxt', 'solver-new122_iter_57198.caffemodel', caffe.TEST)
    plugin = IEPlugin(device="MYRIAD")
    net = IENetwork.from_ir(model="/home/louis/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/solver-new122_iter_100000.xml", weights="/home/louis/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/solver-new122_iter_100000.bin")
    input_blob = next(iter(net.inputs))
    out_blob = next(iter(net.outputs))
    exec_net = plugin.load(network=net)
    im = caffe.io.load_image(im_path)
    im = im*255
    npad = ((7,8), (7,8), (0,0))
    im = np.pad(im, npad, 'symmetric')
    transformers = caffe.io.Transformer({'data':net.inputs[input_blob].shape})
    transformers.set_transpose('data', (2,0,1))
    transformers.set_raw_scale('data',255)
    transformers.set_channel_swap('data', (2,1,0))
    out = exec_net.infer(inputs={input_blob:np.array([transformers.preprocess('data', im)])})
    transmission = np.reshape(out['convC'], (height,width))
    return transmission
After I run my code and the error is:
  File "DehazeNet-new1222.py", line 99, in <module>
    te = TransmissionEstimate(im_path, height, width)
  File "DehazeNet-new1222.py", line 35, in TransmissionEstimate
KeyError: 'convC'
but I checked the file solver-new122_iter_100000.xml ,there do have the Key 'convC'. So what I suppose to do with my code?where I should do some modification?Help me please!!!!I am begging you !!
Shubha_R_Intel
Dear Shaw, Louis,
The error you're getting means that there is no output layer named 'convC'. Layer names are usually hierarchical, meaning, they're not just "convC" but rather something like "layer1/output/convC" .
Hope it helps,
Shubha
