Human pose estimation
Vurc
I am able to run human pose estimation demo with CPU and NCS1, but NCS is stack at parsing input parameters, any advice ?
Vurc.
Shubha_R_Intel
Dear Vurc,
did you mean  NCS is stuck  (not stack) at parsing input parameters, any advice ? I'm not sure what you mean by this. Can you kindly be more specific about the problem ?
Shubha
Vurc
when I start human pose estimation demo, console is stuck at following message : Parsing input arguments.
InferenceEngine:
        API version ............ 1.6
        Build .................. 23780
[ INFO ] Parsing input parameters
This only happens with NCS2.
Vurc
Vurc
is there any update on this?
Vurc.
Shubha_R_Intel
Dear Vurc,
I tried the latest OpenVino 2019 R1.1 release and unfortunately you're correct, it seems to be broken. You are correct, it gets stuck as follows:
C:\Users\sdramani\Documents\Intel\OpenVINO\inference_engine_samples_build\intel64\Release>human_pose_estimation_demo.exe -i cam -m c:\users\sdramani\Downloads\human-pose-estimation-0001.xml -d MYRIAD
InferenceEngine:
I can assure you that it's fixed in the next release however. I know this because I've tested it. I'm terribly sorry that you've experienced this inconvenience !
Please wait for the next release and it will be fixed.
Sincerely,
Shubha
Tenn__Hian-Kun
I also tested it with both NCS 1 and NCS 2. Just for your reference.
For NCS 1, there was error message but followed by normal execution:
InferenceEngine:
	Build .................. custom_releases/2019/R1.1_28dfbfdd28954c4dfd2f94403dd8dfc1f411038b
E: [ncAPI] [    332117] ncDeviceOpen:672	Failed to find suitable device, rc: X_LINK_DEVICE_NOT_FOUND
To close the application, press 'CTRL+C' or any key with focus on the output window
[ INFO ] Execution successful
For NCS 2, there's only errors without any output:
InferenceEngine:
E: [ncAPI] [    373198] ncDeviceOpen:672	Failed to find suitable device, rc: X_LINK_DEVICE_NOT_FOUND
E: [xLink] [    597121] dispatcherEventReceive:347	dispatcherEventReceive() Read failed -1 | event 0x7fe2a9b28c60 XLINK_READ_REL_REQ
E: [xLink] [    597121] eventReader:233	eventReader stopped
E: [watchdog] [    597712] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    598711] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    599710] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    600709] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    601708] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    602707] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    603706] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    604706] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    605705] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    606704] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    607703] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    608702] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    609701] sendPingMessage:132	Failed send ping message: X_LINK_ERROR
E: [watchdog] [    609701] watchdog_routine:327	[0xd53900] device, not respond, removing from watchdog
Tenn__Hian-Kun
Hi, Shubha R.,
I am wondering why only the "Human Pose Estimation demo + NCS 2" suffers from present OpenVINO version? Maybe not only this demo, because I haven't tested all the samples... If possible, would you please share more information about the cause?
BR.
tellus__jb
Hi
I can confirm the same problem ( stuck frequently while loading human-pose-estimation-0001.bi with ncs2 )
    Description ....... myriadPlugin
I'm able to run yolo3 on two ncs2 sticks ( multithread) repeatedly..without any stuck error
( meaning I probably have a decent setup )
Human pose estimation sample, seems to have some randomness in its behaviour when loading
 executableNetwork = plugin.LoadNetwork(netReader.getNetwork(), {});
It will fail and get stuck, at least one out of three run. No exception just stuck
Running the exact same code with ncs1 no load error ....
Can't figure out what so special about ( smaller than yolo3 )
human-pose-estimation-0001.bin
/JB
tellus__jb
More tests
Compiled latest inference-engine
dldt/inference-engine
Recompiled human-pose-estimation
Converted input_model human-pose-estimation.onnx
https://github.com/Daniil-Osokin/lightweight-human-pose-estimation.pytorch
 /deployment_tools/model_optimizer/mo.py --data_type=FP16 --input_model human-pose-estimation.onnx --input data --mean_values data[128.0,128.0,128.0] --scale_values data[256] --output stage_1_output_0_pafs,stage_1_output_1_heatmaps
Result, still unstable behaviour frequently stuck on ( no exceptions thrown )
Any ideas ?
Tenn__Hian-Kun
Hi, everyone,
The human pose demo seems only problematic in 2019 R1.1.
When I read Shubha R. mentioned that it is fixed in the next release (and good news, it's available now), I started to suspect that maybe only R1.1 has the problem. Therefore I rolled back to previous installation of OpenVINO (R1.0.1), and the demo run without any problem.
And just as Shubha R. had mentioned in the previous reply, the new release (R.2) has fixed the problem, so just update to the newest version and try the demo again.
Shubha_R_Intel
Dear Tenn, Hian-Kun,
Please definitely report back here if human pose doesn't work for you in OpenVino 2019R2. It should work fine. Please confirm it !
Shubha
Tenn__Hian-Kun
Hi Shubha,
Sorry for my (previously) unclear post.
When I posted that, I actually have tried OpenVINO R2 and the human pose demo worked perfectly. Therefore I wrote "the new release (R.2) has fixed the problem", but that sentence was after "And just as Shubha R. had mentioned in the previous reply" and it might cause the confusion.
Thank you and the team for the effort. (All I want now is getting NCS 2's temperature, but it is out of the topic here... :-p)
Hiankun
Shubha_R_Intel
Thank you for clarifying ! I'm glad that this is working for you on OpenVino 2019R2.
Shubha
