So I'm still new in facial recognition and using openvino.
I'm trying to work with the face_recognition_demo.
I'm having this error, and I can't understand its source.
Hi Aya Abidi,
Thank you for reaching out. Most probably, this error is due to no setupvars.bat. Please set the environment variables and run the demo again using below steps:
The steps to run the Interactive Face Recognition Demo
(https://docs.openvinotoolkit.org/2020.3/_demos_python_demos_face_recognition_demo_README.html) :
1.Set the environment variables. You can follow:
2.Go to the face recognition demo path:
cd <INSTALL_DIR>\openvino_2020.3.194\deployment_tools\open_model_zoo\demos\python_demos\face_recognition_demo
3.Run Installation and dependencies for the Interactive Face Recognition Demo:
pip install -r requirements.txt
4.Lastly, run the demo:
python ./face_recognition_demo.py -h
Syamimi Fauzi
hello Syamimi_Intel,
thank you for replying to my question.
So I followed these steps
so I always get this warning about the libmmd.dll, again I researched for a solution, but I couldn't find the source of this problem.
requirements already satisfies because I went through this steps before
this error shows up
it's an OpenCV error so I thought to search for a solution I found this :
pip uninstall opencv-python
opencv-contrib-python
but the same cv2 error is still showing
So what did I do wrong, or what did I miss
Hi Aya Abidi,
pip uninstall opencv-python is used for uninstalling OpenCV.
You mentioned about some solutions that you searched. I presume you saw the solution below:
https://datascience.stackexchange.com/a/20330
Here, the user used the above command to remove previous versions of opencv-python and opencv-contrib-python installed his/her system. If you notice correctly, installing opencv was suggested as the next immediate step.
You will get import cv2 ImportError when cv2 module is not properly installed on your machine. As such, please install OpenCV using the following command:
pip install opencv-python
After that, open a new terminal and set the environment variables. Then, try to run the demo again.
I've re-verified the steps on my side, and the demo is working as intended.
Syamimi Fauzi
According to messages you posted you do not have Intel Compiler redistributable installed (the warning about libmmd.dll when running setupvars.bat). I think older OpenVINO (2020.3) requires it for one of components.
Intel C++ Compiler Installer Redist package can be downloaded here: https://software.intel.com/content/www/us/en/develop/articles/redistributable-libraries-for-intel-c-and-fortran-2020-compilers-for-windows.html
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
