6574 Discussions
Incorrect results on using accuracy_checker with efficientdet model
siddhantsahu
Goal: Evaluate efficientdet-d3 model on COCO validation dataset using accuracy_checker
Steps taken:
  1. Download efficientdet-d3 and freeze graph using steps mentioned on this repository.
  2. Convert the frozen graph in Step 1 to OpenVino IR with precision FP32.
  3. Use the following config.yaml to run accuracy checker. I just took the efficientdet-d0-tf.yml file found under accuracy_checker/configs/ and modified it. I have used COCO's validation dataset that has 5000 images.
models:
  - datasets:
      - name: ms_coco_detection
        data_source: val2017
        metrics:
          - type: coco_precision
        annotation_conversion:
          images_dir: /home/siddhant.sahu/pot_data/dataset/val2017/
          converter: mscoco_detection
          annotation_file: /home/siddhant.sahu/pot_data/dataset/instances_val2017.json
        preprocessing:
          - type: resize
            aspect_ratio_scale: fit_to_window
          - type: padding
            pad_type: right_bottom
        postprocessing:
          - type: faster_rcnn_postprocessing_resize
          - type: shift_labels
            offset: 1
    launchers:
      - adapter: ssd
        batch: 1
        device: CPU
        framework: dlsdk
        model: /home/siddhant.sahu/pot_data/models/efficientdet/fp32/frozen_inference_graph.xml
        weights: /home/siddhant.sahu/pot_data/models/efficientdet/fp32/frozen_inference_graph.bin
When I execute the above step, I get a coco_precision value of 0.01% which is incorrect.
To ensure that the model conversion using model optimizer was executed correctly, I have checked the AP value using custom code I wrote and got 0.435, same as what's mentioned here
What am I missing here?
Labels (2)
IntelSupport
Community Manager
Hi Siddhantsahu,
Thanks for reaching out. We are investigating this and will get back to you with the information soon.
Aznie
IntelSupport
Community Manager
Hi Siddahantsahu,
Thank you for your patient. We have confirmed that efficientdet-d3 is not yet be supported within OpenVINO toolkit. You may still be able to utilize our accuracy checker tool for the above-mentioned model but we cannot confirm nor provide any exact result as it is yet to be validated by our OpenVINO development team.
Aznie
siddhantsahu
Efficientdet works with OpenVino - I have tested it already. Anyway, I spent some more time trying to figure out the issue and was able to get non-zero results of map (mean average precision) and coco_precision metric using the accuracy_checker tool. I'm not sure if the results are correct.
I used DL workbench to get the command that was being run in the background whenever accuracy is evaluated. Using that, I modified the config to the following:
models:
  - datasets:
        metrics:
          - type: map
            integral: max
            overlap_threshold: 0.5
          images_dir: /home/pot_data/dataset/val2017/
          has_background: true
          use_full_label_map: false
          annotation_file: /home/pot_data/dataset/instances_val2017.json
        preprocessing:
          - type: auto_resize
        postprocessing:
          - type: resize_prediction_boxes
    launchers:
      - adapter: ssd
        batch: 1
        device: CPU
        framework: dlsdk
        model: /home/pot_data/models/efficientdet/fp32/frozen_inference_graph.xml
        weights: /home/pot_data/models/efficientdet/fp32/frozen_inference_graph.xml
The documentation of accuracy_checker module can be improved with working configs of models. The efficientdet config that's present in the repository (path is accuracy_checker/configs/) seems to be incorrect because it returns 0 map and 0 coco_precision.
IntelSupport
Community Manager
Hi Siddhant Sahu,
That particular config file you are using belongs to the Efficientdet-d0, not Efficientdet-d3. As mentioned before, you can use the file but the result might not accurate as we cannot validate any correct value for accuracy checker with Efficientdet-d3. Even though you can get a value with editing/adding some of the metrics, we don’t have any exact mAP value to determine the correctness of the value that you get.
Aznie
IntelSupport
Community Manager
Hi Siddhantsahu,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
