6574 Discussions
Inference speed with INT8 model on a bit old CPU
timosy
I prepared INT8 model, and tested it on a new CPU. I found that the inferece speed gets fast, this is OK. But, I tested the inference using the same model on a bit old CPU, I found that it does not get fast. How should I check whether CPU supports INT8 model or not?
Labels (3)
IntelSupport
Community Manager
Hi Timosy,
Thanks for reaching out.
The slow inference on old CPU is expected based on the hardware configuration and model layer framework. Refer to the  Intel® Distribution of OpenVINO™ toolkit Benchmark Results for the inference performance on a specified hardware configuration.
Apart from that, INT8 is supported with CPU plugin. Check out the Supported Devices, Supported Model Formats, and Supported Layers documentation for more details.
Aznie
IntelSupport
Community Manager
Hi Timosy,
Aznie
IntelSupport
Community Manager
Hi Timosy,
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Aznie
