6605 Discussions
Performance Issue about quantization from FP32 to INT8
spartazhc_
I am trying to do quantization refering to 302-pytorch-quantization-aware-training.ipynb and testing throughput for now.
it looks good on my server(Intel(R) Xeon(R) Platinum 8280M CPU @ 2.70GHz), about 3.35x speed up
Benchmark FP32 model (IR)
Count: 385 iterations
Duration: 10012.54 ms
Latency:
Throughput: 45.04 FPS
Benchmark INT8
model (IR) Count: 993 iterations
Duration: 10001.73 ms
Latency:
Throughput: 151.35 FPS
however, I downloaded the model and run on my laptop (Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz), less than 2x speed up is aquired.
benchmark_app.exe -m .\net_r2c32s_int8.xml -d CPU -api sync -t 20
Latency:
Median: 234.69 ms
AVG: 229.48 ms
MIN: 98.20 ms
MAX: 317.67 ms
Throughput: 4.26 FPS
benchmark_app.exe -m .\net_r2c32s_fp32.xml -d CPU -api sync -t 20
Latency:
Median: 372.04 ms
AVG: 326.20 ms
MIN: 154.71 ms
MAX: 677.04 ms
Throughput: 2.69 FPS
What's the reason of this performance issue?
BR,
Spartazhc.
Peh_Intel
Hi Spartazhc,
Inferencing model on different platform (hardware) is the main reason for getting different performance.
Quantizing a FP32 model into an INT8 model helps to improve the performance (FPS increased) on the same platform. But it is expected to be not getting the same ratio of the increased speed from various platform.
You can refer to Intel® Distribution of OpenVINO™ toolkit Benchmark Results to observe the performance (throughput) of various platform. You can notice that the ratio of the increased speed from inferencing a FP32 model to an INT8 model are different on various platform.
Peh
Peh_Intel
Hi Spartazhc,
Peh
spartazhc_
Thanks for your reply!
So I would like to get it clear that, the reason of different speedup ratio is just the platform optimization. Not because of I do the quantization on Xeon but benchmark it on Core?
BR,
Spartazhc
Peh_Intel
Hi Spartazhc,
Yes, you are correct.
For your information, when downloading Intel’s Pre-Trained Models without specifying precision, you will get three precision models, FP32, FP16 and INT8. Hence, this INT8 model does not limited to be used on the specific platform that used to quantize the model. This INT8 model is useable for any supported platform.
Peh
Peh_Intel
Hi Spartazhc,
This thread will no longer be monitored since your question has been answered. If you need any additional information from Intel, please submit a new question.
Peh
