I run the benchmark_app on my PC, and inference time on GPU is slower (295 ms) than CPU (31 ms). Is there any setting I am missing?
(anomalib) C:\Users\me>benchmark_app -m omz_models/intel/asl-recognition-0004/FP16/asl-recognition-0004.xml -d GPU -hint throughput
[Step 1/11] Parsing and validating input arguments
[ WARNING ] -nstreams default value is determined automatically for a device. Although the automatic selection usually provides a reasonable performance, but it still may be non-optimal for some cases, for more information look at README.
[Step 2/11] Loading OpenVINO
[ INFO ] OpenVINO:
API version............. 2022.1.0-7019-cdb9bec7210-releases/2022/1
[ INFO ] Device info
GPU
Intel GPU plugin........ version 2022.1
Build................... 2022.1.0-7019-cdb9bec7210-releases/2022/1
[Step 3/11] Setting device configuration
[Step 4/11] Reading network files
[ INFO ] Read model took 78.13 ms
[Step 5/11] Resizing network to match image sizes and given batch
[ INFO ] Network batch size: 1
[Step 6/11] Configuring input of the model
[ INFO ] Model input 'input' precision f32, dimensions ([N,C,D,H,W]): 1 3 16 224 224
[ INFO ] Model output 'output' precision f32, dimensions ([...]): 1 100
[Step 7/11] Loading the model to the device
[ INFO ] Compile model took 8302.98 ms
[Step 8/11] Querying optimal runtime parameters
[ INFO ] DEVICE: GPU
[ INFO ] AVAILABLE_DEVICES , ['0']
[ INFO ] RANGE_FOR_ASYNC_INFER_REQUESTS , (1, 2, 1)
[ INFO ] RANGE_FOR_STREAMS , (1, 2)
[ INFO ] OPTIMAL_BATCH_SIZE , 1
[ INFO ] MAX_BATCH_SIZE , 1
[ INFO ] FULL_DEVICE_NAME , Intel(R) UHD Graphics 630 (iGPU)
[ INFO ] OPTIMIZATION_CAPABILITIES , ['FP32', 'BIN', 'FP16']
[ INFO ] GPU_UARCH_VERSION , 9.0.0
[ INFO ] GPU_EXECUTION_UNITS_COUNT , 24
[ INFO ] PERF_COUNT , False
[ INFO ] GPU_ENABLE_LOOP_UNROLLING , True
[ INFO ] CACHE_DIR ,
[ INFO ] COMPILATION_NUM_THREADS , 16
[ INFO ] NUM_STREAMS , 1
[ INFO ] PERFORMANCE_HINT_NUM_REQUESTS , 0
[ INFO ] DEVICE_ID , 0
[Step 9/11] Creating infer requests and preparing input data
[ INFO ] Create 4 infer requests took 31.64 ms
[ WARNING ] No input files were given for input 'input'!. This input will be filled with random values!
[ INFO ] Fill input 'input' with random values
[Step 10/11] Measuring performance (Start inference asynchronously, 4 inference requests, inference only: True, limits: 60000 ms duration)
[ INFO ] Benchmarking in inference only mode (inputs filling are not included in measurement loop).
[ INFO ] First inference took 85.86 ms
[Step 11/11] Dumping statistics report
Count: 816 iterations
Duration: 60549.62 ms
Latency:
Median: 295.50 ms
AVG: 296.06 ms
MIN: 152.10 ms
MAX: 344.38 ms
Throughput: 13.48 FPS
(anomalib) C:\Users\me>benchmark_app -m omz_models/intel/asl-recognition-0004/FP16/asl-recognition-0004.xml -d CPU -hint latency
[ INFO ] OpenVINO:
CPU
openvino_intel_cpu_plugin version 2022.1
[ INFO ] Read model took 34.31 ms
[ INFO ] Compile model took 232.60 ms
[ INFO ] DEVICE: CPU
[ INFO ] AVAILABLE_DEVICES , ['']
[ INFO ] RANGE_FOR_ASYNC_INFER_REQUESTS , (1, 1, 1)
[ INFO ] RANGE_FOR_STREAMS , (1, 16)
[ INFO ] FULL_DEVICE_NAME , Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
[ INFO ] OPTIMIZATION_CAPABILITIES , ['FP32', 'FP16', 'INT8', 'BIN', 'EXPORT_IMPORT']
[ INFO ] INFERENCE_NUM_THREADS , 0
[ INFO ] Create 1 infer requests took 0.00 ms
[Step 10/11] Measuring performance (Start inference asynchronously, 1 inference requests, inference only: True, limits: 60000 ms duration)
[ INFO ] First inference took 63.08 ms
Count: 1917 iterations
Duration: 60029.65 ms
Latency:
Median: 31.37 ms
AVG: 31.22 ms
MIN: 22.52 ms
MAX: 51.78 ms
Throughput: 31.93 FPS
1
Hi Spiovesan,
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Aznie
Hi Spiovesan,
Thanks for reaching out.
Firstly, your inference above is comparing GPU (throughput mode) and CPU (latency mode).
For your information, by default, the Benchmark App is inferencing in asynchronous mode. The calculated latency measures the total inference time (ms) required to process the number of inference requests.
In addition, 4 inference requests are created when running Benchmark App on CPU with default parameters while running Benchmark App on GPU with default parameters, 16 inference requests are created.
You can re-run Benchmark App by setting the same inference requests when inferencing on CPU and GPU and compare the inference results again. The result might be inconsistent however it is acceptable where the value is quite close for both devices.
benchmark_app -m asl-recognition-0004.xml -d CPU -hint latency/throughput -nireq 4
benchmark_app -m asl-recognition-0004.xml -d GPU -hint latency/throughput -nireq 4
Below is my validation on CPU and GPU:
1)Latency mode
CPU:
GPU:
2) Throughput mode
CPU:
GPU:
Aznie
Hi Spiovesan,
Aznie
![](/skins/images/7746D4550810124E96DD2FD9957552B1/responsive_peak/images/icon_anonymous_message.png)
