6574 Discussions
Inferencing a model that takes 2 inputs using openvino 2022 c++ API
ShashankKumar
I am trying to run inference on a model that takes 2 images as input. I am using openvino 2022(c++ interface), can you please suggest on how to properly do it? Or is it even supported currently?
IntelSupport
Community Manager
Hi ShashankKumar,
Thanks for reaching out.
It is possible by specifying the inputs directly in the command. Below is the example of Image Classification Async C++ Sample with two image inputs.
Command:
classification_sample_async -i <IMAGE1_PATH> <IMAGE2_PATH> -m <path_to_model>
Output:
Aznie
IntelSupport
Community Manager
Hi ShashankKumar,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
