Inferring OpenVINO on Windows
Younis__Khaled
I had built the OpenVino model on ubuntu environment, how can I call (invoke) it on windows machine?
Shubha_R_Intel
Dear Younis, Khaled,
OpenVino is developed in a compliant cross-platform way so that the same code runs across Windows and Linux with minimal modifications.  With Mac OSX there are exceptions but running OpenVino tools back and forth between Ubuntu and Windows should be mostly seamless.
To run code which you developed on Ubuntu Openvino in a Windows environment, you will have to make some minimal changes. But first, you must install OpenVino for Windows. Please follow the below instructions to do that:
http://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_windows.html
Once you have installed OpenVino on Windows 10, take a look at the samples :
http://docs.openvinotoolkit.org/latest/_docs_IE_DG_Samples_Overview.html
Should you have specific questions or errors, please feel free to post them here.
Thanks for using OpenVino !
Shubha
