Install OpenVINO on VMWare Linux
Pugach__Yaroslav
I am trying to install OpenVINO 2020.1 on VMWare Ubuntu 18.04 x64. The installer warned me that it could not detect Intel GPU on my machine. My processor is Core i7 4712HQ and it does have integrated graphics. I though it might be related to virtualization. Is it supported? Perhaps, there are some additional steps to make it detect the IGPU?
Sahira_Intel
Hi Yaroslav,
I think this might be an issue with your VMWare configurations. Are you running as a root user? Can you list the output of the following command:
lspci -vvv -nn
Sahira
Pugach__Yaroslav
I didn't seem to change anything in my VMWare config.
OpenVINO installer was run by "sudo ./install_GUI.sh".
And below is the output for "lspci -vvv -nn":
00:00.0 Host bridge [0600]: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX Host bridge [8086:7190] (rev 01)
	Subsystem: VMware Virtual Machine Chipset [15ad:1976]
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Kernel driver in use: agpgart-intel
00:01.0 PCI bridge [0604]: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX AGP bridge [8086:7191] (rev 01) (prog-if 00 [Normal decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV+ VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
	I/O behind bridge: 0000f000-00000fff
	Memory behind bridge: fff00000-000fffff
	Prefetchable memory behind bridge: fff00000-000fffff
	Secondary status: 66MHz+ FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- <SERR- <PERR-
	BridgeCtl: Parity- SERR- NoISA+ VGA- MAbort- >Reset- FastB2B+
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
00:07.0 ISA bridge [0601]: Intel Corporation 82371AB/EB/MB PIIX4 ISA [8086:7110] (rev 08)
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
00:07.1 IDE interface [0101]: Intel Corporation 82371AB/EB/MB PIIX4 IDE [8086:7111] (rev 01) (prog-if 8a [ISA Compatibility mode controller, supports both channels switched to PCI native mode, supports bus mastering])
	Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Latency: 64
	Region 0: [virtual] Memory at 000001f0 (32-bit, non-prefetchable) [size=8]
	Region 1: [virtual] Memory at 000003f0 (type 3, non-prefetchable)
	Region 2: [virtual] Memory at 00000170 (32-bit, non-prefetchable) [size=8]
	Region 3: [virtual] Memory at 00000370 (type 3, non-prefetchable)
	Region 4: I/O ports at 1060 [size=16]
	Kernel driver in use: ata_piix
	Kernel modules: pata_acpi
00:07.3 Bridge [0680]: Intel Corporation 82371AB/EB/MB PIIX4 ACPI [8086:7113] (rev 08)
	Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Interrupt: pin ? routed to IRQ 9
	Kernel modules: i2c_piix4
00:07.7 System peripheral [0880]: VMware Virtual Machine Communication Interface [15ad:0740] (rev 10)
	Subsystem: VMware Virtual Machine Communication Interface [15ad:0740]
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 64 (1500ns min, 63750ns max)
	Interrupt: pin A routed to IRQ 16
	Region 0: I/O ports at 1080 [size=64]
	Region 1: Memory at febfe000 (64-bit, non-prefetchable) [size=8K]
	Capabilities: <access denied>
	Kernel driver in use: vmw_vmci
	Kernel modules: vmw_vmci
00:0f.0 VGA compatible controller [0300]: VMware SVGA II Adapter [15ad:0405] (prog-if 00 [VGA controller])
	Subsystem: VMware SVGA II Adapter [15ad:0405]
	Latency: 64, Cache Line Size: 32 bytes
	Region 0: I/O ports at 1070 [size=16]
	Region 1: Memory at e8000000 (32-bit, prefetchable) [size=128M]
	Region 2: Memory at fe000000 (32-bit, non-prefetchable) [size=8M]
	[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
	Kernel driver in use: vmwgfx
	Kernel modules: vmwgfx
00:10.0 SCSI storage controller [0100]: LSI Logic / Symbios Logic 53c1030 PCI-X Fusion-MPT Dual Ultra320 SCSI [1000:0030] (rev 01)
	Subsystem: VMware LSI Logic Parallel SCSI Controller [15ad:1976]
	Interrupt: pin A routed to IRQ 17
	Region 0: I/O ports at 1400 [size=256]
	Region 1: Memory at feba0000 (64-bit, non-prefetchable) [size=128K]
	Region 3: Memory at febc0000 (64-bit, non-prefetchable) [size=128K]
	[virtual] Expansion ROM at c0008000 [disabled] [size=16K]
	Kernel driver in use: mptspi
	Kernel modules: mptspi
00:11.0 PCI bridge [0604]: VMware PCI bridge [15ad:0790] (rev 02) (prog-if 01 [Subtractive decode])
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=68
	I/O behind bridge: 00002000-00003fff
	Memory behind bridge: fd500000-fdffffff
	Prefetchable memory behind bridge: 00000000e7b00000-00000000e7ffffff
	Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- <SERR- <PERR-
	BridgeCtl: Parity- SERR+ NoISA+ VGA- MAbort- >Reset- FastB2B-
00:15.0 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0, Cache Line Size: 32 bytes
	Interrupt: pin ? routed to IRQ 24
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	I/O behind bridge: 00004000-00004fff
	Memory behind bridge: fd400000-fd4fffff
	Prefetchable memory behind bridge: 00000000e7a00000-00000000e7afffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
	Kernel driver in use: pcieport
00:15.1 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 25
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	I/O behind bridge: 00008000-00008fff
	Memory behind bridge: fd000000-fd0fffff
	Prefetchable memory behind bridge: 00000000e7600000-00000000e76fffff
00:15.2 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 26
	Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
	I/O behind bridge: 0000c000-0000cfff
	Memory behind bridge: fcc00000-fccfffff
	Prefetchable memory behind bridge: 00000000e7200000-00000000e72fffff
00:15.3 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 27
	Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
	Memory behind bridge: fc800000-fc8fffff
	Prefetchable memory behind bridge: 00000000e6e00000-00000000e6efffff
00:15.4 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 28
	Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
	Memory behind bridge: fc400000-fc4fffff
	Prefetchable memory behind bridge: 00000000e6a00000-00000000e6afffff
00:15.5 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 29
	Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
	Memory behind bridge: fc000000-fc0fffff
	Prefetchable memory behind bridge: 00000000e6600000-00000000e66fffff
00:15.6 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 30
	Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
	Memory behind bridge: fbc00000-fbcfffff
	Prefetchable memory behind bridge: 00000000e6200000-00000000e62fffff
00:15.7 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 31
	Bus: primary=00, secondary=0a, subordinate=0a, sec-latency=0
	Memory behind bridge: fb800000-fb8fffff
	Prefetchable memory behind bridge: 00000000e5e00000-00000000e5efffff
00:16.0 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 32
	Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
	I/O behind bridge: 00005000-00005fff
	Memory behind bridge: fd300000-fd3fffff
	Prefetchable memory behind bridge: 00000000e7900000-00000000e79fffff
00:16.1 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 33
	Bus: primary=00, secondary=0c, subordinate=0c, sec-latency=0
	I/O behind bridge: 00009000-00009fff
	Memory behind bridge: fcf00000-fcffffff
	Prefetchable memory behind bridge: 00000000e7500000-00000000e75fffff
00:16.2 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 34
	Bus: primary=00, secondary=0d, subordinate=0d, sec-latency=0
	I/O behind bridge: 0000d000-0000dfff
	Memory behind bridge: fcb00000-fcbfffff
	Prefetchable memory behind bridge: 00000000e7100000-00000000e71fffff
00:16.3 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 35
	Bus: primary=00, secondary=0e, subordinate=0e, sec-latency=0
	Memory behind bridge: fc700000-fc7fffff
	Prefetchable memory behind bridge: 00000000e6d00000-00000000e6dfffff
00:16.4 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 36
	Bus: primary=00, secondary=0f, subordinate=0f, sec-latency=0
	Memory behind bridge: fc300000-fc3fffff
	Prefetchable memory behind bridge: 00000000e6900000-00000000e69fffff
00:16.5 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 37
	Bus: primary=00, secondary=10, subordinate=10, sec-latency=0
	Memory behind bridge: fbf00000-fbffffff
	Prefetchable memory behind bridge: 00000000e6500000-00000000e65fffff
00:16.6 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 38
	Bus: primary=00, secondary=11, subordinate=11, sec-latency=0
	Memory behind bridge: fbb00000-fbbfffff
	Prefetchable memory behind bridge: 00000000e6100000-00000000e61fffff
00:16.7 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 39
	Bus: primary=00, secondary=12, subordinate=12, sec-latency=0
	Memory behind bridge: fb700000-fb7fffff
	Prefetchable memory behind bridge: 00000000e5d00000-00000000e5dfffff
00:17.0 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 40
	Bus: primary=00, secondary=13, subordinate=13, sec-latency=0
	I/O behind bridge: 00006000-00006fff
	Memory behind bridge: fd200000-fd2fffff
	Prefetchable memory behind bridge: 00000000e7800000-00000000e78fffff
00:17.1 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 41
	Bus: primary=00, secondary=14, subordinate=14, sec-latency=0
	I/O behind bridge: 0000a000-0000afff
	Memory behind bridge: fce00000-fcefffff
	Prefetchable memory behind bridge: 00000000e7400000-00000000e74fffff
00:17.2 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 42
	Bus: primary=00, secondary=15, subordinate=15, sec-latency=0
	I/O behind bridge: 0000e000-0000efff
	Memory behind bridge: fca00000-fcafffff
	Prefetchable memory behind bridge: 00000000e7000000-00000000e70fffff
00:17.3 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 43
	Bus: primary=00, secondary=16, subordinate=16, sec-latency=0
	Memory behind bridge: fc600000-fc6fffff
	Prefetchable memory behind bridge: 00000000e6c00000-00000000e6cfffff
00:17.4 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 44
	Bus: primary=00, secondary=17, subordinate=17, sec-latency=0
	Memory behind bridge: fc200000-fc2fffff
	Prefetchable memory behind bridge: 00000000e6800000-00000000e68fffff
00:17.5 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 45
	Bus: primary=00, secondary=18, subordinate=18, sec-latency=0
	Memory behind bridge: fbe00000-fbefffff
	Prefetchable memory behind bridge: 00000000e6400000-00000000e64fffff
00:17.6 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 46
	Bus: primary=00, secondary=19, subordinate=19, sec-latency=0
	Memory behind bridge: fba00000-fbafffff
	Prefetchable memory behind bridge: 00000000e6000000-00000000e60fffff
00:17.7 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 47
	Bus: primary=00, secondary=1a, subordinate=1a, sec-latency=0
	Memory behind bridge: fb600000-fb6fffff
	Prefetchable memory behind bridge: 00000000e5c00000-00000000e5cfffff
00:18.0 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 48
	Bus: primary=00, secondary=1b, subordinate=1b, sec-latency=0
	I/O behind bridge: 00007000-00007fff
	Memory behind bridge: fd100000-fd1fffff
	Prefetchable memory behind bridge: 00000000e7700000-00000000e77fffff
00:18.1 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 49
	Bus: primary=00, secondary=1c, subordinate=1c, sec-latency=0
	I/O behind bridge: 0000b000-0000bfff
	Memory behind bridge: fcd00000-fcdfffff
	Prefetchable memory behind bridge: 00000000e7300000-00000000e73fffff
00:18.2 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 50
	Bus: primary=00, secondary=1d, subordinate=1d, sec-latency=0
	Memory behind bridge: fc900000-fc9fffff
	Prefetchable memory behind bridge: 00000000e6f00000-00000000e6ffffff
00:18.3 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 51
	Bus: primary=00, secondary=1e, subordinate=1e, sec-latency=0
	Memory behind bridge: fc500000-fc5fffff
	Prefetchable memory behind bridge: 00000000e6b00000-00000000e6bfffff
00:18.4 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 52
	Bus: primary=00, secondary=1f, subordinate=1f, sec-latency=0
	Memory behind bridge: fc100000-fc1fffff
	Prefetchable memory behind bridge: 00000000e6700000-00000000e67fffff
00:18.5 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 53
	Bus: primary=00, secondary=20, subordinate=20, sec-latency=0
	Memory behind bridge: fbd00000-fbdfffff
	Prefetchable memory behind bridge: 00000000e6300000-00000000e63fffff
00:18.6 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 54
	Bus: primary=00, secondary=21, subordinate=21, sec-latency=0
	Memory behind bridge: fb900000-fb9fffff
	Prefetchable memory behind bridge: 00000000e5f00000-00000000e5ffffff
00:18.7 PCI bridge [0604]: VMware PCI Express Root Port [15ad:07a0] (rev 01) (prog-if 00 [Normal decode])
	Interrupt: pin ? routed to IRQ 55
	Bus: primary=00, secondary=22, subordinate=22, sec-latency=0
	Memory behind bridge: fb500000-fb5fffff
	Prefetchable memory behind bridge: 00000000e5b00000-00000000e5bfffff
02:00.0 USB controller [0c03]: VMware USB1.1 UHCI Controller [15ad:0774] (prog-if 00 [UHCI])
	Subsystem: VMware USB1.1 UHCI Controller [15ad:1976]
	Physical Slot: 32
	Latency: 64
	Interrupt: pin A routed to IRQ 18
	Region 4: I/O ports at 2080 [size=32]
	Kernel driver in use: uhci_hcd
02:01.0 Ethernet controller [0200]: Intel Corporation 82545EM Gigabit Ethernet Controller (Copper) [8086:100f] (rev 01)
	Subsystem: VMware PRO/1000 MT Single Port Adapter [15ad:0750]
	Physical Slot: 33
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0 (63750ns min), Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 19
	Region 0: Memory at fd5c0000 (64-bit, non-prefetchable) [size=128K]
	Region 2: Memory at fdff0000 (64-bit, non-prefetchable) [size=64K]
	Region 4: I/O ports at 2000 [size=64]
	[virtual] Expansion ROM at fd500000 [disabled] [size=64K]
	Kernel driver in use: e1000
	Kernel modules: e1000
02:02.0 Multimedia audio controller [0401]: Ensoniq ES1371/ES1373 / Creative Labs CT2518 [1274:1371] (rev 02)
	Subsystem: Ensoniq Audio PCI 64V/128/5200 / Creative CT4810/CT5803/CT5806 [Sound Blaster PCI] [1274:1371]
	Physical Slot: 34
	Region 0: I/O ports at 2040 [size=64]
	Kernel driver in use: snd_ens1371
	Kernel modules: snd_ens1371
02:03.0 USB controller [0c03]: VMware USB2 EHCI Controller [15ad:0770] (prog-if 20 [EHCI])
	Subsystem: VMware USB2 EHCI Controller [15ad:0770]
	Physical Slot: 35
	Region 0: Memory at fd5ef000 (32-bit, non-prefetchable) [size=4K]
	Kernel driver in use: ehci-pci
02:05.0 SATA controller [0106]: VMware SATA AHCI controller [15ad:07e0] (prog-if 01 [AHCI 1.0])
	Subsystem: VMware SATA AHCI controller [15ad:07e0]
	Physical Slot: 37
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 64
	Interrupt: pin A routed to IRQ 56
	Region 5: Memory at fd5ee000 (32-bit, non-prefetchable) [size=4K]
	[virtual] Expansion ROM at fd510000 [disabled]
	Kernel driver in use: ahci
	Kernel modules: ahci
Munesh_Intel
Hi Yaroslav,
To enable GPU directly on VMware virtual machine, you need to run VMware ESXi directly on a host with VT-d (Intel® Virtualization Technology for Directed I/O) enabled and also enable the PCI Passthrough of the GPU.
To achieve this, you first need to install VMware vSphere Hypervisor, which is built on VMware vSphere ESXi architecture. I have attached the following document, ‘VMware ESXi Installation and Setup’, for your perusal.
VMware DirectPath I/O is the technology that gives a virtual machine (VM) direct access to a physical PCI and PCIe hardware devices on the host. The steps to configure VMDirectPath I/O direct PCI device connections for virtual machines are given in the following page:
https://kb.vmware.com/s/article/1010789
Additional information:
  1. To find out if your Intel® processor supports and is enabled for Intel® Virtualization Technology, please refer to the following article, ‘Does My Processor Support Intel® Virtualization Technology?’, for detailed information.
           https://www.intel.com/content/www/us/en/support/articles/000005486/processors.html
        2. It is equally important to note that OpenVINO supports only 6th to 10th generation Intel Core processors with Intel® Iris® Pro graphics              and Intel HD Graphics. (Your Intel® Core™ i7-4712HQ Processor is a 4th generation processor by the way).
            The relevant information regarding these can be found at the following links:
            https://software.intel.com/content/www/us/en/develop/tools/openvino-toolkit/hardware.html
            https://ark.intel.com/content/www/us/en/ark/products/78932/intel-core-i7-4712hq-processor-6m-cache-up-to-3-30-ghz.html
Munesh
