Installation issues in OPENVINO
Deepak_K_Intel1
I was trying to install OPENVINO by following steps from  https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html.
I got stuck in Ste2 of
Configure all supported frameworks at the same time
Step 1: Go to the Model Optimizer prerequisites directory:
             cd /opt/intel/openvino/deployment_tools/model_optimizer/install_prerequisites
Step 2: Run the script to configure the Model Optimizer for Caffe, TensorFlow, MXNet, Kaldi*, and ONNX:
             sudo ./install_prerequisites.sh
Error is attached below
Shubha_R_Intel
Dear Kumar, Deepak,
This is not an OpenVino problem. It's a lab connectivity problem. Perhaps proxy settings are wrong ?
Please follow these steps correctly and make sure you are using a supported Linux OS:
http://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html
Shubha
GeerthanaaRavi
I'm currently working on OpenVino. I'm also facing the same error and stuck in Model Optimizer Configuration Steps. If I used my mobile data it's working perfectly but when using a proxy then I face the same error as yours. Have you found a solution for this?  If yes, could you please share your solution here. It will very helpful for me.
Thank you.
