Installing and running Openvino in Ubuntu 18.04 Missing Test-generator
WDomo
Guys
I have followed the Ubuntu 16.04 documentation (because there isn't any for 18.04) and get to testing squeezenet
Caffe specific parameters:
    - Enable resnet optimization:     True
    - Path to the Input prototxt:     /home/frank/openvino_models/models/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.prototxt
    - Path to CustomLayersMapping.xml:     Default
    - Path to a mean file:     Not specified
    - Offsets for a mean file:     Not specified
Model Optimizer version:     2019.1.1-83-g28dfbfd
[ ERROR ]
Detected not satisfied dependencies:
    test-generator: not installed, required: 0.1.1
Please install required versions of components or use install_prerequisites script
/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/install_prerequisites/install_prerequisites_caffe.sh
Note that install_prerequisites scripts may install additional components.
Error on or near line 202; exiting with status 1
I have run the install prerequisites script 3 times and the thing doesn't work.
How doI fix this please
Kind reagrds
Frank
WDomo
How does this help me?
There is a file missing
WDomo
processor       : 0
vendor_id       : GenuineIntel
cpu family      : 6
model           : 58
model name      : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
stepping        : 9
microcode       : 0x21
cpu MHz         : 1679.003
cache size      : 8192 KB
physical id     : 0
siblings        : 8
core id         : 0
cpu cores       : 4
apicid          : 0
initial apicid  : 0
fpu             : yes
fpu_exception   : yes
cpuid level     : 13
wp              : yes
flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm /proc/cpuinfo
Shubha_R_Intel
Dear Domoney, William,
At this time, Ubuntu 18.04 is not supported by OpenVino. Some community members have gotten it working though.
Shubha
FARSHAD_A_Intel
I run MO and DLDT on 18.04LTS without any issue. below is the run on SqueezeNet1.1 with FP32 datatype. please have a look and let me know the difference with your setup. I maybe able to duplicate your issue.
Farshad.
  Model Name: squeezenet1.1
  Model Framework: caffe
  Target Precision: FP32
    /usr/bin/python3 /opt/intel/openvino/dldt/tools/model_downloader/downloader.py --name squeezenet1.1 --output_dir temp
###############|| Start downloading models ||###############
...100%, 9 KB, 50684 KB/s, 0 seconds passed ========= squeezenet1.1.prototxt ====> temp/classification/squeezenet/1.1/caffe/squeezenet1.1.prototxt
###############|| Start downloading weights ||###############
...100%, 4834 KB, 4184 KB/s, 1 seconds passed ========= squeezenet1.1.caffemodel ====> temp/classification/squeezenet/1.1/caffe/squeezenet1.1.caffemodel
###############|| Start downloading topologies in tarballs ||###############
###############|| Post processing ||###############
========= Changing input dimensions in squeezenet1.1.prototxt =========
    /usr/bin/python3 /opt/intel/openvino/dldt/model-optimizer/mo.py --input_model /home/fakhbari/proj/dsl_pathfinding/models/squeezenet1.1/squeezenet1.1.caffemodel --scale 255.0 --mean_values [123.68,116.779,103.939] --output_dir /home/fakhbari/proj/dsl_pathfinding/models/ir/squeezenet1.1/FP32/ --data_type FP32
Model Optimizer arguments:
Common parameters:
        - Path to the Input Model:      /home/fakhbari/proj/dsl_pathfinding/models/squeezenet1.1/squeezenet1.1.caffemodel
        - Path for generated IR:        /home/fakhbari/proj/dsl_pathfinding/models/ir/squeezenet1.1/FP32/
        - IR output name:       squeezenet1.1
        - Log level:    ERROR
        - Batch:        Not specified, inherited from the model
        - Input layers:         Not specified, inherited from the model
        - Output layers:        Not specified, inherited from the model
        - Input shapes:         Not specified, inherited from the model
        - Mean values:  [123.68,116.779,103.939]
        - Scale values:         Not specified
        - Scale factor:         255.0
        - Precision of IR:      FP32
        - Enable fusing:        True
        - Enable grouped convolutions fusing:   True
        - Move mean values to preprocess section:       False
        - Reverse input channels:       False
        - Path to the Input prototxt:   /home/fakhbari/proj/dsl_pathfinding/models/squeezenet1.1/squeezenet1.1.prototxt
Model Optimizer version:        unknown version
[ WARNING ]
        protobuf: installed: 3.0.0, required: 3.6.1
/opt/intel/openvino_2019_1.133/dldt_2019_R1.1/model-optimizer/install_prerequisites/install_prerequisites_caffe.sh
[ SUCCESS ] Generated IR model.
[ SUCCESS ] XML file: /home/fakhbari/proj/dsl_pathfinding/models/ir/squeezenet1.1/FP32/squeezenet1.1.xml
[ SUCCESS ] BIN file: /home/fakhbari/proj/dsl_pathfinding/models/ir/squeezenet1.1/FP32/squeezenet1.1.bin
[ SUCCESS ] Total execution time: 2.78 seconds.
WDomo
Thanks Shubba
That isn't what the marketing guy told me this morning
Hi Frank,
I just spoke to our OpenVINO Technical Consulting Engineer and she informs me that Ubuntu 18.04 is supported and has been since the start of the year.  Updates to our documentation and websites are lagging behind.  So you should be good to go.  Have you tried installing it on 18.04?
/Scott.
Could we perhaps get everyone in Intel singing off the same hymnsheet?
Kind regards
Frank
Shubha_R_Intel
Dearest Domoney, William,
Maybe what the marketing guy meant is that people have gotten OpenVino working on Ubuntu 18.04 . As Farshad (and others in the OpenVino community) have showed, they've been successful with Ubuntu 18.04 .
But The OpenVino Linux Installation Doc makes it pretty clear:
Operating Systems
Ubuntu 16.04.x long-term support (LTS), 64-bit: Minimum supported kernel is 4.14
CentOS 7.4, 64-bit (for target only)
Yocto Project Poky Jethro v2.0.3, 64-bit (for target only and requires modifications)
Shubha
WDomo
thanks Farshad
Convert a model with Model Optimizer
Run python3 /opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo.py --input_model /home/frank/openvino_models/models/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.caffemodel /home/frank/openvino_models/ir/FP32//classification/squeezenet/1.1/caffe --data_type FP32
Common parameters:
    - Path to the Input Model:     /home/frank/openvino_models/models/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.caffemodel
    - Path for generated IR:     /home/frank/openvino_models/ir/FP32//classification/squeezenet/1.1/caffe
    - Log level:     ERROR
    - Mean values:     Not specified
    - Scale factor:     Not specified
[ ERROR ]
WDomo
Aha
I manually installed Test-generator and the problem goes away.
pip install test-generator
WDomo
Dear Shubba and Farshad
Thank you so much for your help
Both the sample applications now run
On to the next application
Kind regards
Frank
Shubha_R_Intel
Dear Domoney, William aka Frank,
Thanks kindly for reporting your findings to the community. This is a sharing community and we rely on each other to make progress on our projects. Thank you again and so glad that you fixed it - got OpenVino up and running on Ubuntu 18 !
Shubha
