6616 Discussions
InvalidArgumentError (see above for traceback): Shape [-1,10] has negative dimensions
Hi ,everyone! I encountered a problem. The following tensorflow code are from my training cnn code of mnist data.
num_input = 784
num_classes = 10
dropout = 0.75
X = tf.placeholder("float",[None,num_input],name="input")
Y = tf.placeholder("float",[256,num_classes],name="output")
keep_prob = tf.placeholder("float")
but when I use command mvNCCompile, mvNCCompile ckpt_555/model.ckpt.meta -s 12 -in=input -on=output -is 28 28 -o mnist_model.graph
there are some errors:
[[Node: output = Placeholder[dtype=DT_FLOAT, shape=[?,10], _device="/job:localhost/replica:0/task:0/cpu:0"]()]]
Can aynone help to tell me how to solve this problem.
@guohua24 Please try the solution I mentioned at https://ncsforum.movidius.com/discussion/comment/1557/#Comment_1557 and let me know if this solves your issue.
thanks a lot!
@guohua24 You're welcomed!
@Tome_at_Intel
Please help me to solve the following problem.
when I use the following command: mvNCCompile tcs_inference.meta -w tcs_inference -s 12 -in input -on output -o tsc_inference.graph
the output is: mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead
if d.decorator_argspec is not None), _inspect.getargspec(target))
/usr/local/bin/ncsdk/Controllers/FileIO.py:52: UserWarning: You are using a large type. Consider reducing your data sizes for best performance
"Consider reducing your data sizes for best performance\033[0m")
@guohua24 I'd love to help you but I'm not sure what the problem is. It looks like part of your log may be cut off/missing.
@Tome_at_Intel
my WeChat 13910875471. Can We communicate with WeChat?
@guohua24 If you are concerned about the warning You are using a large type. Consider reducing your data sizes for best performance, I want you to know that it is an outdated warning and should be removed soon. This message shows up if you are using 32 bit data in your model, but since the weights for the model are always converted to fp16, you should not be worried about any performance issues.
