I am looking to use clDNN via the c-api, and have a few queries about the cldnn_tensor (tensor size) struct.
1. Should I always set batch_num and feature_num to 1, and spatial_num to 2 ? This would always make:
sizes[0] = batch size sizes[1] = feature size sizes[2] = spatial_0 (x?) sizes[3] = spatial_1 (y?)
2. Is the x-coordinate (or width) always first, and y-coordinate (or height) always second? Even though formats mention y first, eg cldnn_format_yxfb.
3. It seems I need to pad 4...CLDNN_TENSOR_DIM_MAX size elements to '1' to get the byte calculation right.
How should I pad the elements in the case where "cldnn_tensor" is representing and offset, rather than a size (eg lower_size) ie, should I put size[0] and size[1] to 0 for no batch/feature offset?
4. Is cldnn_format_bfyx the best format for conv2d weights?
5. To confirm, the conv2d bias size should be [1,1,Outputs,1], ie, "spatial_0" should be the feature size. A little odd, but I can live with it.
I complete example of using the c api to run a conv2d would answer most of these questions. Is there one somewhere?
Hugh
In answer to my own questions
1,2,3. It works if you always use a 4D vector, x first, padded with 1s everywhere
For the offsets, you describe a 4D vector with the feature and batch 'size' (offset) = 0
4 - seems to work
5 works - but is a little odd.
I would also add that the strings in cldnn_engine_configuration need to be initialized with the empty string "", rather than the null pointer otherwise you get a crash.
But otherwise, everything seems to work out ok.
