6578 Discussions
Is it mandatory to use a powered USB hub for Movidius NCS when using on PYNQ Z2?
KSP00
I have tried installing NCSDK on PYNQ Z2 without using powered USB hub. But it is not installing. Should i mandatory use powered USB?
David_C_Intel
Hello KSP00,
Thank you for contacting Intel Customer Support.
We have not tested this board with the Intel® Neural Compute Stick (NCS). However, in general, if the USB port can provide enough power (500 mah) a powered USB Hub is not required.
If you have more questions, I will be glad to help you.
David C.
A Contingent Worker at Intel
David_C_Intel
Hi KSP00,
I am contacting you to give a follow up on this case. Could you please tell me if your issue is solved?
Feel free to contact us in case you need further assistance.
David C.
