6581 Discussions
Is it possible for ncsdk to support OpenCV 4.0.0?
I do NOT want to uninstall my installed OpenCV and then install OpenCV for Movidius again…
@jiapei100
[Caution] This is an unofficial procedure.
That's pretty easy.
Perhaps, commenting out all the scripts of "ncsdk/install-opencv.sh" and "ncsdk/uninstall-opencv.sh" will make it work.
I've been running opencv 4.0.0 with it for a while with no problems. What I did was:
  1. Build and install opencv as you normally would
  2.
  3. run the sdk installer (which will uninstall your opencv)
  4.
  5. Rerun the opencv installer (should be quick since its already built) which should remove the sdk opencv
  6.
Although PINTOs solution is probably better.
jiapei100
Hi, mdata:
It's still fails to run make install, I pasted all the messages at https://pastebin.com/4H5rfPy6
In fact, I did a lot of manual installation, instead of grabbing the packages directly from repository.
A lot of my PYTHON packages are pip installed to ~/.local/lib/python3.7/site-packages
And, boost is ALSO manually installed, it does NOT have a package like libboost-all-dev .
Isn't there a way to provide a cmake way to build ncsdk all by customers ourselves?
Cheers
Pei
