6574 Discussions
Is there a Tool to measure load on Myriad devices
Siegfried
Load of an Movidius Extension.
Can we measure the load of a Movidius Extension? For example like the CPU load with Process Explorer.
Peh_Intel
Hi Siegfried,
Changing the settings of the Service Configuration File might fulfil your needs.
Modify the hddl_service.config file in <OV>\3rdparty\hddl\config\hddl_service.config and update change "device_snapshot_mode": "none", to "device_snapshot_mode": "full".
After changing a configuration file, restart the hddldaemon in <OV>\3rdparty\hddl\bin and run your application with -d HDDL from another window.
The following YouTube video walks you through the process, however, it's for an older release and some parts may have changed.
https://www.youtube.com/watch?v=nyBvFF_z8Sw
Peh
Peh_Intel
Hi Siegfried,
If the “load” you mean is the memory consumption of loading network, then the memory consumption can be measured for HDDL plugin through configuration parameter (HDDL_DEVICE_MEMORY_USED). However, this configuration parameter is not available for MYRIAD plugin (Intel® Neural Compute Stick 2).
Peh
Siegfried
Thank you for the answer. Good to know how to see memory usage. But i hoped there is something for computation load. Lets say there are lots of asynchrounous requests runnung (or scheduled) on the VPU. Is one parallel reuqest enough to occupy the whole unit, or can i run 10 requests in parallel? How can we measure what the limit are?
We have a system which starts inferences on demand. Sometimes this could be a high number of inferences, somtimes its just a few requests. We wanted to have a way to debug this and see how hard the vpu is working right now. The only thing we see is, how long it takes until the inference is finished.
Peh_Intel
Hi Siegfried,
Peh
Siegfried
Hi Peh,
Thank you. util% looks very promising.
Siegfried
Peh_Intel
Hi Siegfried,
This thread will no longer be monitored since we had answered your question. If you need any additional information from Intel, please submit a new question.
Peh
