deblurring.py import error
gb8
Hi, again.
When I test deblurring.py, similar error produces.
import Deblurring --> error
Though I am not Python expert, I modified the code I can.
Simply added model_api path to sys.path as follow solved those error.
sys.path.append(str(Path(__file__).resolve().parents[2] / 'common/python/openvino/model_zoo/model_api'))
Next, import PerformanceMetrics error occues.
from ..performance_metrics import PerformanceMetrics
2022-04-01 15_32_43-async_pipeline.py - open_model_zoo_org [WSL_ OV_Ub20] - Visual Studio Code.png
 it seems kind of relative path error.
I set just no parent directory -  'from performance_metrics import PerformanceMetrics', solves it.
That's it.
gb8
Vladimir_Dudnik
@gb8 according to the OMZ demo descriptions, you need to properly initialize environment, in order to run demos. In particular, for python demos you need to install OMZ Model API component (that can be achieved by simple command
pip install <omz_dir>/demos/common/python
Vladimir_Dudnik
Peh_Intel
Hi gb8,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Peh
