Is there any demo which uses face-person-detection-retail-002 model.?
R__A
Hi
I have modified the pedestrian tracker demo code and in that I am detecting person and faces. For this purpose, I am using `person-detection-retail-0013` for person detection and `face-detection-retail-0004` for face detection. But the issue is that, it becomes a bit difficult sometime to check which face belongs to which person, as detection is being done by two different models.
Then I came across this model `face-person-detection-retail-002` which I believe can detect face and person. But I am unable to find how to use it. Is there any demo available which is using this model so that I can get a reference code from it.
Luis_at_Intel
Based on the Inference Engine Samples, the face-person-detection-retail-0002 model should work with any demo that supports SSD*-based models. For example the Hello Shape Infer SSD demo or the Object Detection for SSD Async demo. There are also some Python* samples that support SSD* based models and these are included in the toolkit under <path-to>openvino/deployment_tools/inference_engine/samples/python_samples
Let me know if you have any additional questions.
@Luis_at_Intel
R__A
Hi
Can this also work with pedestrian tracker demo.?
Luis_at_Intel
Not sure if this is possible with the sample code provided as is, I think you may have to modify the program to be able to use the model. For your information I attempted to run the sample program (as provided) using the face-person-detection-retail-0002 model and I get an [ ERROR ] Face Detection network should have only one output.
Let me know if you have any other questions.
kalocsai
Hi Luis_at_Intel,
I am trying to get a hold of the face-person-detection-retail-0002 model. As it seems like you have used this model before, could I possibly ask you to send it to me or provide me with a link where I could download it from.
Thank you very much for your help!
peter
Kamma__Vijayakumar
I am able to get the outputs for both face and person with different nodes but how to combine them ?
face_result = person_face_infer_network1.get_output(person_currReq,"detection_out_face")
pede_result = person_face_infer_network1.get_output(person_currReq,"detection_out_pedestrian")
not sure how to combine the face and person.
kalocsai
Hi R_A,
I am in desperate need of the model: face-person-detection-retail-0002. As it seems like you have used this model earlier, could I possible ask you to send that model to me or provide me with a link where I could download it from. This model is no longer available from Intel's website. You help with this is very much appreciated!
peter
