6573 Discussions
Issue to load IR or ONNX model on NCS2+Raspberry Pi4
fredf
Error when loading a model converted using MMDeploy on RPi4 (OpenVino 2021.4.2):
  1. >>> net = ie.read_network(model="end2end.xml", weights="end2end.bin")
  2. >>> exec_net = ie.load_network(network=net, device_name="MYRIAD")
  3. Traceback (most recent call last):
  4. File "<stdin>", line 1, in <module>
  5. File "ie_api.pyx", line 403, in openvino.inference_engine.ie_api.IECore.load_network
  6. File "ie_api.pyx", line 442, in openvino.inference_engine.ie_api.IECore.load_network
  7. RuntimeError: [ GENERAL_ERROR ]
  8. /home/jenkins/agent/workspace/private-ci/ie/build-linux-debian_9_arm/b/repos/openvino/inference-engine/src/vpu/common/src/ngraph/transformations/dynamic_to_static_shape.cpp:199 DynamicToStaticShape transformation encountered dynamic node Tile_1450 of type Tile ver. 0, but only [Ceiling ver. 0, Clamp ver. 0, Concat ver. 0, Convert ver. 0, Exp ver. 0, ExpGatherElements ver. 0, Floor ver. 0, Log ver. 0, MatMul ver. 0, Relu ver. 0, ...] types are supported for dynamic nodes
OpenVino 2022.1 not found
Thank you
Hairul_Intel
Hi fredf,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Hairul
Hairul_Intel
Hi fredf,
Please share details regarding your model, is it a custom or pre-trained model, the topology, source repository, etc.
For your information, this error occurs when the model is not supported on MYRIAD devices.
The supported models for MYRIAD Plugin is available on the following pages:
Hairul
Hairul_Intel
Hi fredf,
Hairul
