Accuracy Configuration Failed
KCZ
I had converted my custom yolov4 model into OpenVINO IR model following this tutorial. https://github.com/TNTWEN/OpenVINO-YOLOV4.git
But when I am going to create new accuracy report, it shows "Accuracy Configuration Failed".
I am running with:
Ubuntu 18.04
Openvino_2021.4.582
The error log is as follows:
Traceback (most recent call last):
File "/opt/intel/openvino_2021/deployment_tools/tools/workbench/wb/main/console_tool_wrapper/accuracy_tools/accuracy/check_accuracy.py", line 120, in <module>
main()
File "/opt/intel/openvino_2021/deployment_tools/tools/workbench/wb/main/console_tool_wrapper/accuracy_tools/accuracy/check_accuracy.py", line 106, in main
profile=args.profile,
File "/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker/accuracy_checker/evaluators/model_evaluator.py", line 348, in process_dataset_sync
batch_input_ids, batch_meta, enable_profiling, output_callback)
File "/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker/accuracy_checker/evaluators/model_evaluator.py", line 367, in _process_batch_results
batch_predictions = self.adapter.process(batch_predictions, batch_identifiers, batch_meta)
File "/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker/accuracy_checker/adapters/yolo.py", line 444, in process
self.processor, self.threshold)
File "/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker/accuracy_checker/adapters/yolo.py", line 135, in parse_output
raw_bbox = DetectionBox(bbox[0], bbox[1], bbox[2], bbox[3], bbox[4], bbox[5:])
IndexError: index 0 is out of bounds for axis 0 with size 0
Zulkifli_Intel
Hi KCZ,
Please share your model, configuration file (.yml), and annotated dataset with us.
You can go to How to use predefined configuration files and Dataset Preparation Guide for references.
Sincerely,
Zulkifli
KCZ
Hi, thanks for replying.
The YOLOv4-tiny model is trained on 2 classes with custom datasets
The validation dataset exceeds the upload size limit.
I am using the val2017 coco dataset and the file layout of the archived file is as follows:
|-annotations
        |-instances_val2017.json
|-val2017
The configuration file cannot be attached here so i just copy the part related to MS COCO dataset:
datasets:
- name: ms_coco_mask_rcnn
annotation_conversion:
converter: mscoco_mask_rcnn
annotation_file: instances_val2017.json
has_background: True
sort_annotations: True
annotation: mscoco_mask_rcnn.pickle
dataset_meta: mscoco_mask_rcnn.json
data_source: val2017
- name: ms_coco_mask_rcnn_short_80_classes
annotation_file: instances_val2017_short.json
annotation: mscoco_mask_rcnn_short_80.pickle
dataset_meta: mscoco_mask_rcnn_short_80.json
- name: ms_coco_mask_rcnn_short_80_classes_without_background
has_background: False
annotation: mscoco_mask_rcnn_short_80_without_bkgr.pickle
dataset_meta: mscoco_mask_rcnn_short_80_without_bkgr.json
- name: ms_coco_mask_rcnn_short_91_classes
use_full_label_map: True
annotation: mscoco_mask_rcnn_short_91.pickle
dataset_meta: mscoco_mask_rcnn_short_91.json
preprocessing:
- type: resize
aspect_ratio_scale: fit_to_window
dst_height: 800
dst_width: 1365
- type: padding
dst_height: 800
dst_width: 1365
pad_type: right_bottom
postprocessing:
- type: faster_rcnn_postprocessing_resize
dst_height: 800
dst_width: 1365
- name: ms_coco_detection_91_classes
converter: mscoco_detection
annotation: mscoco_det_91.pickle
dataset_meta: mscoco_det_91.json
preprocessing:
- type: resize
dst_height: 600
dst_width: 1024
- type: padding
dst_height: 600
dst_width: 1024
postprocessing:
dst_height: 600
dst_width: 1024
- name: ms_coco_detection_80_class_without_background
use_full_label_map: False
annotation: mscoco_det_80.pickle
dataset_meta: mscoco_det_80.json
- name: ms_coco_detection_80_class_with_background
annotation: mscoco_det_80_bkgr.pickle
dataset_meta: mscoco_det_80_bkgr.json
- name: ms_coco_detection_90_class_without_background
data_source: MSCOCO/val2017
annotation_file: MSCOCO/annotations/instances_val2017.json
annotation: mscoco_det_90.pickle
dataset_meta: mscoco_det_90.json
- name: ms_coco_keypoints
converter: mscoco_keypoints
annotation_file: person_keypoints_val2017.json
sort_key: image_size
annotation: mscoco_keypoints.pickle
dataset_meta: mscoco_keypoints.json
metrics:
- name: AP
type: coco_precision
max_detections: 20
- name: ms_coco_val2017_keypoints
remove_empty_images: True
images_dir: val2017
annotation: mscoco_val2017_keypoints.pickle
dataset_meta: mscoco_val2017_keypoints.json
metrics:
- name: AP
type: coco_orig_keypoints_precision
- name: ms_coco_val2017_keypoints_5k_images
remove_empty_images: False
images_dir: val2017
annotation: mscoco_val2017_keypoints_5k_images.pickle
dataset_meta: mscoco_val2017_keypoints_5k_images.json
metrics:
- name: AP
Zulkifli_Intel
Hello KCZ,
The configuration file that you shared might not be in the correct format. Please share with us the full configuration file that you used to run with the accuracy checker tool.
You can refer to the sample accuracy-check.yml file for the YOLO-v4-tiny model in Open Model Zoo.
https://github.com/openvinotoolkit/open_model_zoo/blob/master/models/public/yolo-v4-tiny-tf/accuracy-check.yml
Sincerely,
Zulkifli
Zulkifli_Intel
Hello KCZ,
Thank you for your question. This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Zulkifli
