6575 Discussions
RunTime error : Filed to allocate graph : Myriad device is not opened
Besma_Guesmi
Hi !
I use Ubuntu 20.04 VM on windows, I tried to run a model using NCS2, it works fine on windows but on Ubuntu VM show the error below even the NCS2 is detected when I run (lsusb)
Error : RunTime error : Filed to allocate graph : Myriad device is not opened
Any help ?
Zulkifli_Intel
Hello Besma,
Greetings,
Have you tried changing the USB controller from 2.0 to 3.0 for all USB filters in the virtual machine settings?
Another thing you can try is to follow the instruction from the Installation and Configuration with a Virtual Machine in USB configuration section.
I hope this information helps.
Sincerely,
Zulkifli
Zulkifli_Intel
Hello Besma,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Sincerely,
Zulkifli
