6594 Discussions
JOB SCRIPT ERROR: Remote job failed, code: 1
AFuTing
Hi Sir
I try to convert my VGG16 ONNX model for the 11th Gen Intel(R) Core(TM) i5-1145G7E @ 2.60GHz but got 'JOB SCRIPT ERROR: Remote job failed, code: 1'.
Does anyone know what is the problems?
JesusE_Intel
Hi Ting,
Thanks for providing your log file and model. Looks like the issue is with the configuration parameters during model optimization on DL Workbench.
Received message {'log': 'Exception: Image shape (224, 224, 3) is not compatible with input shape [1, 3, 224, 224]! Make sure -i parameter is valid.\n', 'error': None}
I wasn't able to access your dataset, however, I was able to obtain results using your model with the configuration below and a generated dataset. Could you please give that a try and let me know if you have any issues? If you run into any issues, please share access to your dataset for further debugging.
Jesus
JesusE_Intel
Hi AFuTing,
Would it be possible to share your model and dataset to reproduce the issue? I tested with a generated dataset and the VGG16 model from Open Model Zoo and didn't run into this issue. Can you also share the log file from DL Workbench?
To download log file:
  1. Launch DL Workbench
  2. Click on Gear Icon (Right Top Corner)
  3. Click on Download Log
Jesus
AFuTing
Hi Jesus
Sorry, I correct the log file as the attachment.
Sincerely,
Ting
JesusE_Intel
Hi Ting,
Jesus
JesusE_Intel
