6577 Discussions
Output for tensor name 'boxes' is not found.
Farhâd
Hello:
Trying to run the sample Hello Object Detection in:
https://docs.openvino.ai/latest/notebooks/004-hello-detection-with-output.html
Get the following error:
RuntimeError                              Traceback (most recent call last)
<ipython-input-13-91d59ca51c94> in <module>
      6
      7 input_layer_ir = compiled_model.input(0)
----> 8 output_layer_ir = compiled_model.output("boxes")
RuntimeError: Output for tensor name 'boxes' is not found.
Please take a look
Hairul_Intel
Hi Farhâd,
For your information, this error is related to the model's output. For the Hello Object Detection notebook tutorial, it is using the horizontal-text-detection-0001 from Open Model Zoo which has the "boxes" output.
Please ensure that the IR model (.xml and .bin) files are included in the following directory when running the notebook:
You can refer to the Outputs section for more information.
Hairul
Farhâd
thanks.
how can i access those IR models ( xml + bin )?
Hairul_Intel
Hi Farhâd,
Following the OpenVINO™ Notebooks Windows installation guide, you can access the IR model (.xml and .bin) files for the Hello Object Detection tutorial located in the following directory:
<openvino_notebooks_dir>\notebooks\004-hello-detection\model
Hairul
Hairul_Intel
Hi Farhâd,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Hairul
