LOADING ir FILES
owaisali
I am using unet provided by intel and successfully used it for BRATS but when ever i change the dataset this error occurs at the stage where i am running inference using IR files
Data batch channel count (4) does not match filter input channel count (1).
(decathlon) E:\code3\unet-master\2D>python plot_openvino_inference_examples.py --device MYRIAD
2021-01-31 12:28:08.797145: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'cudart64_101.dll'; dlerror: cudart64_101.dll not found
2021-01-31 12:28:08.797355: I tensorflow/stream_executor/cuda/cudart_stub.cc:29] Ignore above cudart dlerror if you do not have a GPU set up on your machine.
File "plot_openvino_inference_examples.py", line 137, in <module>
seed=args.seed)
File "E:\code3\unet-master\2D\dataloader.py", line 39, in __init__
self.file_list = tf.io.gfile.glob(self.dirName)
File "C:\Users\owais\anaconda3\envs\decathlon\lib\site-packages\tensorflow\python\lib\io\file_io.py", line 371, in get_matching_files_v2
compat.as_bytes(pattern))
tensorflow.python.framework.errors_impl.NotFoundError: FindFirstFile failed for: ../data/decathlon/Task01_BrainTumour/2D_model/testing : The system cannot find the path specified.
; No such process
2021-01-31 12:29:54.101117: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'cudart64_101.dll'; dlerror: cudart64_101.dll not found
2021-01-31 12:29:54.107419: I tensorflow/stream_executor/cuda/cudart_stub.cc:29] Ignore above cudart dlerror if you do not have a GPU set up on your machine.
File "plot_openvino_inference_examples.py", line 147, in <module>
net = ie.read_network(model=path_to_xml_file, weights=path_to_bin_file)
File "ie_api.pyx", line 261, in openvino.inference_engine.ie_api.IECore.read_network
File "ie_api.pyx", line 285, in openvino.inference_engine.ie_api.IECore.read_network
RuntimeError: Check 'Dimension::merge(merged_channel_count, data_channel_count, filter_input_channel_count)' failed at C:\j\workspace\private-ci\ie\build-windows-vs2019@2\b\repos\openvino\ngraph\core\src\validation_util.cpp:344:
While validating node 'v1::Convolution Convolution_2 (mrimages[0]:f16{1,4,128,128}, StatefulPartitionedCall/2DUNet_Brats_Decathlon/encodeAa/Conv2D/Transpose5219_const[0]:f16{32,1,3,3}) -> (dynamic?)' with friendly_name 'Convolution_2':
owaisali
The actual problem i am facing here is that the dataset you are using BRATS contains images in .npz format .I need your help in visualizing that dataset. I just want to examine that dataset after which i will be able to fine tune my own dataset over your provided Unet model .I will be highly obliged if you could help me out with this
Thanks in Advance
Iffa_Intel
Greetings,
I can see that you are facing the error of  Could not load dynamic library 'cudart64_101.dll'; dlerror: cudart64_101.dll not found
You may refer here to fix it: https://stackoverflow.com/questions/59823283/could-not-load-dynamic-library-cudart64-101-dll-on-tensorflow-cpu-only-install
Sincerely,
Iffa
owaisali
The actual problem i am facing here is that the dataset you are using BRATS contains images in .npz format .I need your help in visualizing that dataset. I just want to examine that dataset after which i will be able to fine tune my own dataset over your provided Unet model .I will be highly obliged if you could help me out with this .
Iffa_Intel
Greetings,
I believe you had asked the same question in another thread as well and had already got a response from Munesh.
Please take a look here for our reply in https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/Query/m-p/1248859#M22494
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
