load_network fails silently
Brown_Kramer__Joshua
3,297 檢視
I am trying to run a yolov3 model converted from a pytorch model from this repo: https://github.com/ultralytics/yolov3.  Here is my code.  The script simply exits - with no error, warning, or anything - after printing "Loading on device" and before "Reading image".  This is Windows 10, openvino_2021.2.185, Python 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 17:00:18) [MSC v.1900 64 bit (AMD64)] on win32.  Attached are the xml and bin files.
from openvino.inference_engine import IECore, IENetwork
ie = IECore()
print("Reading network")
net = ie.read_network(model="yolov3-master35.xml",weights="yolov3-master35.bin")
print("Loading on device")
exec_net = ie.load_network(network=net, device_name="CPU")
print("Reading image")
0 積分
5 回應
3,296 檢視
It wouldn't accept the bin file.  Attached is the xml file.
3,294 檢視
3,280 檢視
Here is an error being thrown when loading the network in c++.  I am running the code _openVino->ExecutableNetwork = _openVino->Core->LoadNetwork(_openVino->Network, "CPU"); and the error is "Exception thrown at 0x00007FFCEAFF7D3B (inference_engine_legacyd.dll) in Ocuvera.CV.Tools.NeuralInferenceTester.exe: 0xC0000005: Access violation reading location 0x0000000000000030."
Iffa_Intel
主席
3,246 檢視
Greetings,
I believe this problem is the same as the one you ha posted here:
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/YOLOv3-tutorial-doesn-t-work-in-latest-OpenVINO-but-does-work-in/m-p/1251468#M22614
You could go to the thread for the answer.
Thanks!
Sincerely,
Iffa
Iffa_Intel
主席
3,225 檢視
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
回覆
