6587 Discussions
Linker error after upgrading to 2020.4
subbu
Hey there,
We have a C++ project which uses OpenVINO 2020.1 (In a docker image). I am trying to upgrade the project to use 2020.4 now and make fails at the linking stage complaining the following:
/usr/bin/ld: CMakeFiles/furhat-camcore.dir/src/intel/detectors.cpp.o: undefined reference to symbol '_ZTIN15InferenceEngine10MemoryBlobE'
//opt/intel/openvino/deployment_tools/inference_engine/lib/intel64/libinference_engine_legacy.so: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
CMakeFiles/furhat-camcore.dir/build.make:673: recipe for target 'furhat-camcore' failed
make[2]: *** [furhat-camcore] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/furhat-camcore.dir/all' failed
make[1]: *** [CMakeFiles/furhat-camcore.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
make: *** [all] Error 2
I have all the libraries listed in my LD_LIBRARY_PATH and have ran the setupvars.sh script in the current terminal (and it is also run in the docker image creation process through the Dockerfile). My LD_LIBRARY_PATH output:
/opt/intel/openvino_2020.4.287/data_processing/dl_streamer/lib:/opt/intel/openvino_2020.4.287/data_processing/gstreamer/lib:/opt/intel/openvino_2020.4.287/opencv/lib:/opt/intel/openvino_2020.4.287/deployment_tools/ngraph/lib:/opt/intel/openvino_2020.4.287/deployment_tools/inference_engine/external/hddl_unite/lib:/opt/intel/openvino_2020.4.287/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino_2020.4.287/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino_2020.4.287/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino_2020.4.287/deployment_tools/inference_engine/external/tbb/lib:/opt/intel/openvino_2020.4.287/deployment_tools/inference_engine/lib/intel64:
The same exact project with no changes to the CMakeLists.txt builds with my other Docker image which contains 2020.1.
I have attached my CMakeLists.txt below.
Any help appreciated
Thanks and cheers,
Subbu
subbu
Hey Munesh,
I resolved the issue. The problem wasn't with the Dockerfile but with the CMakeLists. I changed the way I was linking the InferenceEngineLib and that fixed the issue.
Thanks a lot for your help
Cheers,
Subbu
Munesh_Intel
Hi Subbu,
I would suggest you build a new Docker image for OpenVINO 2020.4.
Relevant information is available at the following page:
https://docs.openvinotoolkit.org/2020.4/openvino_docs_install_guides_installing_openvino_docker_linux.html#building-for-cpu
Munesh
subbu
Hey Munesh,
Thanks for your response.
I built a new docker container based on openvino/ubuntu18_dev:2020.4 (https://hub.docker.com/r/openvino/ubuntu18_dev) and no luck. I still have the same exact linker error as I had previously. I have attached my Dockerfile, if you wanna take a look.
Cheers,
Subbu
Munesh_Intel
Hi Subbu,
I suggest you use the attached Dockerfile to build a Docker image. This Dockerfile has been validated for Ubuntu 18.04 LTS.
Munesh
subbu
Hey Munesh,
Cheers,
Subbu
Li__Rachel
May I ask what exact changes did you make in CMakeList?
I have the similar error but for undefined reference to symbol '_ZTVN15InferenceEngine10CNNNetworkE'
Munesh_Intel
Hi Subbu,
Thank you for sharing your findings with our community.
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Munesh
