Load custom tensorflow model in OpenVino Sample
Kaufmann__Elia
Hi there
I trained, froze and converted a custom tensorflow model using the model optimizer. Conversion with the model optimizer completed successfully.
The model is a simple feedforward network that consumes a single image and produces an 8D vector.
To get startet with OpenVino, I adapted the car detection tutorial from:
https://github.com/intel-iot-devkit/inference-tutorials-generic ;
The tutorial runs fine on my laptop when the provided model is loaded (vehicle-detection-adas-0002.xml).
To run the code sample with my own model, I need to adapt the checks for input and outpt sizes (line 223 in ~/inference-tutorials-generic/car_detection_tutorial/step_2/main.cpp) like this:
if (objectSize != 8) { ...  }
if (outputDims.size() != 2) { ... }
When I run the adapted sample and load my own model, the program fails to load the network.
./car_detection_tutorial -m optimized_graph.xml
Output:
InferenceEngine:
	API version ............ 1.4
	Build .................. 17328
[ INFO ] Parsing input parameters
[ INFO ] Reading input
[ INFO ] Loading plugin CPU
	Build .................. lnx_20181004
	Description ....... MKLDNNPlugin
[ INFO ] Loading network files for VehicleDetection
[ INFO ] Batch size is set to 1 for Vehicle Detection
[ INFO ] Checking Vehicle Detection inputs
[ INFO ] Checking Vehicle Detection outputs
[ INFO ] Loading Vehicle Detection model to the CPU plugin
[ ERROR ] std::exception
I am aware that the demo will not work entirely with a different network, but I expected that the network should be at least loaded and the first image should be fed through the network.
I attached the converted model from the model optimizer as well as the original frozen graph from tensorflow.
Thanks for any help!
Severine_H_Intel
Dear Elia,
I tried your network through our benchmark app (included in the samples), which allows to load a model without processing the output. The network is working properly, therefore I think the issue is from the output processing.
From my experience, it is better to ramp up from an easier sample like classification_sample or hello_classification in order to customize a sample. The sample you have chosen is having a more complicated structure that the samples I mention.
Best,
Severine
