6615 Discussions
Loading detection models and reusing (based on multi_camera_multi_person demo)
Zvi
I would like to load a person detector once, use it on one clip and then reuse the model on another clip (based on the MultiCameraTracker demo).
When I try to do this I get an error :
ie_api.pyx in openvino.inference_engine.ie_api.ExecutableNetwork.start_async()
ValueError: Incorrect request_id specified!
I created a python notebook that recreates the problem. Attached.
Adli
Hi Zvi,
Thank you for reaching out to us. I assume that the error is triggered possibly due to request_id is holding information from the previous clip. Try resetting the demo before attempting to execute it on a new clip.
Adli
Zvi
Thanks, but this is exactly my question.
object_detector = multi_camera_multi_target_tracking.Detector(ie, detector,config['obj_det']['trg_classes'],t_detector,detector_device, cpu_extension,1)
 If this is the object detector - this is where the model is loaded. I want to be do this once. How do I reset this object for a different clip (run)?
Adli
Hi Zvi,
If possible, could you share your program (model, file) here for replicating purposes?
Adli
Zvi
It's attached to the original question (Python notebook to reproduce problem) - but attaching again.
Adli
Hi Zvi,
We are currently investigating this issue and will get back to you soon.
Adli
Adli
Hi Zvi,
Thank you for your patience. The 'Multi-Camera Multi-Target Tracking' sample is not designed for reusing the same object_detector variable with different videos.
In order to make your Jupyter Notebook sample code work, you could just reinitialize the 'object_detector' before calling out the 'my_run' function for the second time. So the last section of the code would look like this:
capture = multi_camera_multi_target_tracking.MulticamCapture([clip_name])
my_run(params, config, capture, object_detector, object_recognizer)
Adli
Zvi
Thanks you for your answer.
Could you explain the design issues about the problem of reusing the same object (that is missing in the sample)? Some documentation? What would I need to change? A snippet?
Is this the same for any model that uses IECore?
I know I could reload the model again and rerun but that is exactly what I wish to prevent.
Adli
Hi Zvi,
Adli
Adli
Hi Zvi,
I will close this thread since the issue was solved based on the following Github thread: https://github.com/openvinotoolkit/openvino/issues/3039
Adli
Adli
Hi Zvi,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Adli
