6583 Discussions
How do I use shuffle net in NCS2(Myriad X)?
Tsin__Ross
Hi ,
I tried to use my shufflenet v2 based model in openvino, and see this exception:
and my IR file(not generated by MO ) ia attached.
How can I fix this?
Thank you!
Iffa_Intel
Greetings,
First and foremost, get all OpenVINO toolkit itself (latest 2021.2) with all of its pre-requisite correctly and ensure that you are able to run the example as in this guide: https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_windows.html
Please note that OpenVINO only supports ShufflenetV2 topology on the Caffe model.
You may refer to this guide for conversion purposes: https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_Caffe.html
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
