6575 Discussions
Run asl_recognition_demo Error in tracker.py line 18 ModuleNotFoundError: No module named 'scipy'
Chiu__Hsien_Hsiang
Have followed the ASL Open Model demo page
https://github.com/openvinotoolkit/open_model_zoo/tree/master/demos/python_demos/asl_recognition_demo#running
ASL Recognition Python* Demo
and the commands:
python asl_recognition_demo.py \
-m_a /home/user/asl-recognition-0003.xml \
-m_d /home/user/person-detection-asl-0001.xml \
-i 0 \
-c ./classes.json
PC is using OS: Windows 10,
Command Prompt Run as Administrator
setupvars.bat set correct
asl-recognition-0004 download 2021.1.110 updated.
person-detection-asl-0001 download 2021.1.110 updated.
Video camera ok
Once Run the python asl ... command, it display Error message:
Traceback (most recent call last):
File "asl_recognition_demo.py", line 32, in <module>
from asl_recognition_demo.tracker import Tracker
File "C:\Program Files (x86)\IntelSWTools\openvino_2021.1.110\deployment_tools\open_model_zoo\demos\python_demos\asl_recognition_demo\asl_recognition_demo\tracker.py", line 18, in <module>
from scipy.optimize import linear_sum_assignment
Attached screen picture Command Prompt with Error message for reference
Does someone know how to solve the error? Able to Run the asl_recognition_demo?
Iffa_Intel
Greetings,
Make sure that you had run setupvars each time you open a new terminal/cmd.
The error ModuleNotFoundError: No module named 'scipy' could be that you didn't install scipy, try to install it: pip install scipy.
Sincerely,
Iffa
Iffa_Intel
Greetings,
Sincerely,
Iffa
Chiu__Hsien_Hsiang
Hi Iffa,
Thank you for reply, I have followed instructions and install scipy.
The missing module name 'scipy' error has solved.
attached CMD screen picture for reference
Solution steps:
1. Setupvars.bat
and
2.  pip install scipy
Have another error, Demo Screen shows black screen:
(in video_stream.py", line 123, in _frame_generator
trg_time_step = 1.0 / float(source_fps)
ZeroDivisionError: float division by zero)
After install scipy, move all the xml, bin files in same directory
Run asl_recognition_demo.py Demo again,
C:\Program Files (x86)\IntelSWTools\openvino_2021.1.110\deployment_tools\open_model_zoo\demos\python_demos\asl_recognition_demo>python asl_recognition_demo.py -m_a asl-recognition-0004.xml -m_d person-detection-asl-0001.xml -i 1 -c classes.json
and
have another Error when use Video Camera as "-i 1" source.  (my PC use video camera 1 as source)
the Demo windows will display "Back" screen, no video images ...etc.
on CMD screen shows message
Process Process-1:
File "C:\Users\User\AppData\Local\Programs\Python\Python36\lib\multiprocessing\process.py", line 258, in _bootstrap
self.run()
File "C:\Users\User\AppData\Local\Programs\Python\Python36\lib\multiprocessing\process.py", line 93, in run
self._target(*self._args, **self._kwargs)
File "C:\Program Files (x86)\IntelSWTools\openvino_2021.1.110\deployment_tools\open_model_zoo\demos\python_demos\asl_recognition_demo\asl_recognition_demo\video_stream.py", line 123, in _frame_generator
and the pop up Demo screen is Black screen. Program keep running , but Black screen, not show anything. When Click "ESC" key the Demo window program will terminated back to CMD window.
Attached Demo Windows screen show Black screen error picture for reference.
Does someone know How to solve this error?
Demo windows shows black screen , no images display.
in CMD display "
Program do not crash, still running, but demo windows has no image.
When click ESC key, will terminated windows and back to CMD windows prompt.
Iffa_Intel
Greetings,
We are currently investigating your new issue. We will update you asap.
Thanks!
Sincerely,
Iffa
Chiu__Hsien_Hsiang
Hi Iffa,
Thank you for reply message.
Here are Environment Details details information of 1. version of the OpenVINO™ toolkit version,2. Operating System , 3. Hardware specifications,4. Additional environment information, and 5. Steps to reproduce, information, for reference:
Environment Details
1. Which version of the OpenVINO™ toolkit are you using?
Using openvino_2021.1.110 version
2. Operating System
Windows 10 Pro 64 bits,
Version: 1909
System:
Processor: Intel(R) Core(TM) i7-10510U CPU @ 1.8GHz 2.30 GHz
Installed memory (RAM): 16.0 GB
System type: 64-bit Operating System, x64-based processor
Video Camera:
Intel RealSense(TM) Depth Camera 415 RGB
Intel RealSense(TM) Depth Camera 415 Depth
CMAKE version 3.18.0-rc2
Python 3.6.5
C:\Users\User>pip -V
pip 20.3 from c:\users\user\appdata\local\programs\python\python36\lib\site-packages\pip (python 3.6)
Here are the details steps:
CMD run as Admin
Step 1.
C:\Program Files (x86)\IntelSWTools\openvino_2021.1.110\bin
Run setupvars.bat
Step 2.
Have use Open_Model_Zoo downloader to Download newest asl .xml and .bin fies, using FP32 files to Run
C:\Program Files (x86)\IntelSWTools\openvino_2021.1.110\deployment_tools\open_model_zoo\tools\downloader\intel\asl-recognition-0004\FP32
asl-recognition-0004.XML
asl-recognition-0004.bin
Step 3.
The application is original from OpenViNO_2021.1.110 installation
Step 4.
Have moved the asl .xml and .bin files to same directory
PC connect USB with RealSense Camera is 1
Step 5.
In CMD Run command:
C:\Program Files
Step 6.
Program Demo Window Black Screen Error:
Program Run but the pop up Demo window only display black screen, no image.
During the program run
The CMD windows shows message:
Process Process-1:Traceback (most recent call last):File
line 258, in _bootstrapself.run()File
line 93, in runself._target(*self._args, **self._kwargs)File "C:\Program
Files
line 123, in _frame_generatortrg_time_step = 1.0 /
float(source_fps)ZeroDivisionError: float division by zero
Step 7.
Program No crash, when click ESC key, then program will terminated, and back to CMD windows prompt.
Chiu__Hsien_Hsiang
Hi Iffa,
Have received Rizal reply solution from another post, and the solution is to change the video_stream.py file.
Because the Intel RealSense 415 camera , video frame is 60 PFS.
so need to edit the video_stream.py
Solution:
if source_fps == 0 : source_fps = 60 #replace this number with your camera fps.
just above
in Video_stream.py file
The program can Run and display video images now.
But have another new ASL demo error need to solved.
The Demo Windows only able shows user tracking, but not do any ASL hand signs detection or readings.
Program can only do tracking user when walking around with square lines border and number '0'.
But program does not do any ASL hand sign recognition , nor reading ASL hand signs at all.
When user do any ASL sign , the program did not shows anything detections, and not shows any reading user's hands  ASL hand signs.
For reference: The command that I Run
"python
person-detection-asl-0001.xml -i 1 -c classes.json"
at
Have moved all the .xml and bin files in same directory
both asl-recognition-0004 and person-detection-asl-0001
ASL Demo program error:
Demo Windows program Run, and show video images, program able to tracking user,  but program has not do any ASL hand signs detection , program not do any reading user's hand signs.
Anyone know how to enable the ASL detection and Reading?
or where might be the problem need to be corrected?
Iffa_Intel
It is recommended for you to try the new OpenVINO 2021.2 release where asl_recognition_demo was replaced with gesture_recognition_demo as in this guide: - https://docs.openvinotoolkit.org/latest/omz_demos_python_demos_asl_recognition_demo_README.html
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
