MKLDNNPlugin not loading
Daraen
I'm trying to run OpenVINO samples (currently I'm working with classification_sample), and I have a problem about the plugin MKLDNNPlugin :
[ ERROR ] Cannot find plugin to use :Tried load plugin : MKLDNNPlugin, error: Plugin MKLDNNPlugin cannot be loaded: cannot load plugin: MKLDNNPlugin from : Cannot load library 'MKLDNNPlugin.dll': 126 from cwd: C:\Users\TC\Documents\Intel\OpenVINO\inference_engine_samples_build_2015\intel64\Release, skipping
Of course the file "MKLDNNPlugin.dll" is in the same folder of my "classification_sample.exe".
Somebody can help me ?
Thank you.
Shubha_R_Intel
Dear Daraen:
The plugin does not need to be located in the same folder as classification_sample.exe. My guess is that you didn't execute bin/setupvars.bat
Shubha
Shubha_R_Intel
Dear Daraen:
Shubha
Daraen
Hello Shubha,
Thank you for your reply,
I guess I have to run setupvars.bat each time I run cmd ?
Thank you.
Shubha_R_Intel
Dearest Daraen,
Ha ha. You got it ! At least in the non-open source version of OpenVino running setupvars.bat first (or the Linux equivalent setupvars.sh) is The Golden Rule when you use OpenVino. The dldt open source has a different configuration however and you don't need to run setupvars.sh or *.bat in that case.
Shubha
Daraen
Hello Shubha,
I can run samples from cmd after running setupvars.bat
Now I want to run programs from VS and I got same issues, maybe I have to call setupvars.bat from my program too ?
Thank you.
Shubha_R_Intel
Hi Daraen :
To run a debug build within Visual Studio, first you must change your setupvars.bat to load Debug instead of Release. That's easy, just do a global search/replace on setupvars.bat from Release to Debug.
Then:
  1. open VStudio command prompt ("x64 Native Tools Command Prompt..." from Start Menu)
  2. Run the batch file
  3. Run devenv /UseEnv
Step 3 will bring up Visual Studio with the environment variables from setupvars.bat.
Thanks !
Shubha
Daraen
Dear Shubah,
Thank you very much for helping me !
Shubha_R_Intel
Dear Daraen,
You are welcome.
Have a nice day and thanks for using OpenVino !
Shubha
