MOVIDIUS Neural stick USB 3.0 ?
I am running UBUNTU 16.04 on DELL laptop and just checked the usb connection to my Movidiues stick. (lsusb -vvv)
Bus 001 Device 105: ID 03e7:2150
Device Descriptor:
bLength 18
bDescriptorType 1
** bcdUSB 2.00**
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x03e7
idProduct 0x2150
bcdDevice 0.01
iManufacturer 1 Movidius Ltd.
iProduct 2 Movidius MA2X5X
iSerial 3 03e72150
bNumConfigurations 1
Does it mean it has USB 2.0 interface and not USB 3.0?
Thanx Sandor
I have tried my Neural stick on several PC connected directly to the USB 3.0 ports and also via external USB 3.0 hub, but all the time it seen as USB 2.0 device. (Other USB 3.0 devices are identified correctly.)
As the technical specification say it has to be USB 3.0 I may do something wrong.
Anyone managed to get it work as USB 3.0 device?
(I am just trying to find this out as there is a big difference between 480M or 5G transfer speed, and I suppose this would speed up the prediction also because the time taken by the transfer)
Thanx in advance
Sandor
Thanx a lot for the quick respone! Will check it tomorrow morning.
Thanx a lot. Tested and it is working according to your description.
(Earlier I only checked when it was connected, but not in operation)
How can I put into solved state the question (if there is such)?
S&|
@sseres Glad you have it figured out. For the NCS forums, we currently don't have an option to mark a thread as solved.
