[100%] Building CXX object python/CMakeFiles/pycaffe.dir/caffe/_caffe.cpp.o
c++: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See for instructions.
python/CMakeFiles/pycaffe.dir/build.make:62: recipe for target 'python/CMakeFiles/pycaffe.dir/caffe/_caffe.cpp.o' failed
make[3]: *** [python/CMakeFiles/pycaffe.dir/caffe/_caffe.cpp.o] Error 4
make[3]: Leaving directory '/opt/movidius/ssd-caffe/build'
CMakeFiles/Makefile2:1245: recipe for target 'python/CMakeFiles/pycaffe.dir/all' failed
make[2]: *** [python/CMakeFiles/pycaffe.dir/all] Error 2
make[2]: Leaving directory '/opt/movidius/ssd-caffe/build'
Makefile:127: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/opt/movidius/ssd-caffe/build'
Installation failed. Error on line 498
any ideas what's the problem?
- Tags:
- Caffe
problem solved: I had to increase the memory on the virtual machine
@ai4things Glad you got it to work. How much memory did you set your VM to use to make it work? I'm sure other users may find this information useful. Thanks.
I'm getting the following error while installing on Ubuntu 16.04, I'm not using VM
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to TIFFReadRGBAStrip@LIBTIFF_4.0'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference toPyUnicodeUCS4_FromEncodedObject'
PyNumber_InPlaceDivide'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference toPyString_Size'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyString_FromStringAndSize'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTIFFIsTiled@LIBTIFF_4.0'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyString_InternFromString'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference toPyInt_AsLong'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyUnicodeUCS4_AsWideChar'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTIFFWriteScanline@LIBTIFF_4.0'/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to
TIFFGetField@LIBTIFF_4.0'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTIFFScanlineSize@LIBTIFF_4.0'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyString_AsString'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTIFFReadEncodedTile@LIBTIFF_4.0'/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to
TIFFReadRGBATile@LIBTIFF_4.0'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference toPyString_FromFormat'/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to
TIFFClose@LIBTIFF_4.0'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTIFFRGBAImageOK@LIBTIFF_4.0'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyClass_Type'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference toPyString_FromString'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyFile_AsFile'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference toPy_InitModule4_64'/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to
TIFFOpen@LIBTIFF_4.0'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference toPyInt_Type'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyInt_FromLong'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference toPyFile_FromString'/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to
TIFFReadEncodedStrip@LIBTIFF_4.0'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTIFFSetField@LIBTIFF_4.0'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyNumber_Divide'
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference toPyString_Type'/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to
TIFFSetWarningHandler@LIBTIFF_4.0'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTIFFSetErrorHandler@LIBTIFF_4.0'collect2: error: ld returned 1 exit status
tools/CMakeFiles/convert_annoset.dir/build.make:134: recipe for target 'tools/convert_annoset' failed
make[3]: *** [tools/convert_annoset] Error 1
CMakeFiles/Makefile2:555: recipe for target 'tools/CMakeFiles/convert_annoset.dir/all' failed
make[2]: *** [tools/CMakeFiles/convert_annoset.dir/all] Error 2
system config is:
Memory : 16GB
Processor: Intel Core i7
OS: Ubuntu 16.04
Any idea how to resolve this ?
@vikhanna
I think, It is not a problem of CPU, memory or OS.
Error installing caffe.
And probably there are conflicting versions of libraries other than Caffe that have already been introduced.
It is clear that there is a problem with /opt/movidius/caffe/Makefile .
Since it is very time consuming to solve problems one by one, I think, the fastest solution is to introduce NCSDK in a slim Ubuntu environment.
I have encountered the same problem many times.
If you do not want to destroy the environment, we recommend building an environment with VM (ex. OracleVM Virtualbox).
If you intend to do your best…
git clone https://github.com/BVLC/caffe.git
You need to modify Makefile.config by yourself, paying attention to GPU presence, CUDA presence, PYTHON version, OpenCV version.
Also, it is necessary to modify the environment variables.
Finally, do the following.
make -j4
I hope it will be helpful for you.
