Make Examples Error
Hi all,
I am running into an issue when running 'make examples'. It keeps failing on the making compile step due to an import error. I have opened a new terminal session since running the install, and successfully run the 'hello_ncs.py' example program. This is happening on an Ubuntu 16.04 Virtual Box image on a Win7 Host. I also tried running the pip install separately for pygraphviz.Here is the traceback:
osboxes@osboxes:~/ncsdk$ make examples
./install-opencv.sh
OpenCV Installation Starting
OpenCV already setup for python3
make examples starting.
(cd examples; make)
make[1]: Entering directory '/home/osboxes/ncsdk/examples'
make -C apps/.
make[2]: Entering directory '/home/osboxes/ncsdk/examples/apps'
make -C hello_ncs_py/.
make[3]: Entering directory '/home/osboxes/ncsdk/examples/apps/hello_ncs_py'
nothing to make, use 'make run' to run.
make[3]: Leaving directory '/home/osboxes/ncsdk/examples/apps/hello_ncs_py'
make -C multistick_cpp/.
make[3]: Entering directory '/home/osboxes/ncsdk/examples/apps/multistick_cpp'
making googlenet
(cd ../../caffe/GoogLeNet; make compile; cd ../../apps/multistick_cpp; cp ../../caffe/GoogLeNet/graph ./googlenet.graph;)
make[4]: Entering directory '/home/osboxes/ncsdk/examples/caffe/GoogLeNet'
making prereqs
(cd ../../data/ilsvrc12; make)
make[5]: Entering directory '/home/osboxes/ncsdk/examples/data/ilsvrc12'
make[5]: Leaving directory '/home/osboxes/ncsdk/examples/data/ilsvrc12'
making prototxt
Prototxt file already exists
making caffemodel
caffemodel file already exists
making compile
mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt
Traceback (most recent call last):
File "/usr/local/bin/mvNCCompile", line 35, in
from Controllers.Scheduler import load_myriad_config, load_network
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 25, in
from Controllers.Optimizer import postParsingOptimizations, selectImplementations, streamEverythingSchedule, fixTensors
File "/usr/local/bin/ncsdk/Controllers/Optimizer.py", line 25, in
from Controllers.Parsers.Parser.Convert import Convert
File "/usr/local/bin/ncsdk/Controllers/Parsers/init.py", line 3, in
from .Caffe import loadNetworkObjects, parse
File "/usr/local/bin/ncsdk/Controllers/Parsers/Caffe.py", line 48, in
from Controllers.GraphUtils import drawGraph, drawGraphFromLayers
File "/usr/local/bin/ncsdk/Controllers/GraphUtils.py", line 23, in
import pygraphviz as pgv
File "/usr/local/lib/python3.5/dist-packages/pygraphviz/init.py", line 58, in
from .agraph import AGraph, Node, Edge, Attribute, ItemAttribute, DotError
File "/usr/local/lib/python3.5/dist-packages/pygraphviz/agraph.py", line 26, in
from . import graphviz as gv
File "/usr/local/lib/python3.5/dist-packages/pygraphviz/graphviz.py", line 28, in
_graphviz = swig_import_helper()
File "/usr/local/lib/python3.5/dist-packages/pygraphviz/graphviz.py", line 24, in swig_import_helper
_mod = imp.load_module('_graphviz', fp, pathname, description)
File "/usr/lib/python3.5/imp.py", line 242, in load_module
return load_dynamic(name, filename, file)
File "/usr/lib/python3.5/imp.py", line 342, in load_dynamic
return _load(spec)
ImportError: /usr/local/lib/python3.5/dist-packages/pygraphviz/_graphviz.cpython-35m-x86_64-linux-gnu.so: undefined symbol: Agundirected
Makefile:80: recipe for target 'compile' failed
make[4]: *** [compile] Error 1
make[4]: Leaving directory '/home/osboxes/ncsdk/examples/caffe/GoogLeNet'
cp: cannot stat '../../caffe/GoogLeNet/graph': No such file or directory
Makefile:9: recipe for target 'googlenet' failed
make[3]: *** [googlenet] Error 1
make[3]: Leaving directory '/home/osboxes/ncsdk/examples/apps/multistick_cpp'
Makefile:12: recipe for target 'multistick_cpp/.' failed
make[2]: *** [multistick_cpp/.] Error 2
make[2]: Leaving directory '/home/osboxes/ncsdk/examples/apps'
Makefile:13: recipe for target 'apps/.' failed
make[1]: *** [apps/.] Error 2
make[1]: Leaving directory '/home/osboxes/ncsdk/examples'
Makefile:57: recipe for target 'examples' failed
make: *** [examples] Error 2
Any ideas???
Thanks!
@apie Try going to the caffe/GoogLeNet directory and see if you can successfully do a make compile. If you can’t, I would recommend reinstalling the ncsdk and seeing if that solves the issue.
You can perform an uninstall of the NCSDK by entering the ncsdk root directory and typing in: make uninstall
Afterwards delete the ncsdk folder and its contents
Download a fresh copy of the NCSDK at https://github.com/movidius/ncsdk or do a Git clone https://github.com/movidius/ncsdk to your desired location.
Navigate to the ncsdk folder you just downloaded and type in: make install
Hello @Tome_at_Intel ,
I have tried the solution that you have suggested above. I re-cloned the fresh copy of NCS and tried 'make compile' (after make install is successful). But I'm still getting the same error that is mentioned in the above thread. I would appreciate if you can help with any workarounds to create a graph file. Thanks !!
Hi @apie, the above mentioned solution didn't work for me. Can you please update the thread if you have found any alternative solution for this? Thanks !!
Hello, I actually I got this error resolved. There was an issue with multiple python versions available in the system. So here is what i did.
  • Removed pygraphviz from both python versions. (pip2/pip3 uninstall pygraphviz)
  • rm -rf /usr/local/lib/python3.5/dist-packages/pygraphviz && rm -rf /usr/local/lib/python2.7/dist-packages/pygraphviz
  • pip3 install pygraphviz --install-option="--include-path=/usr/include/graphviz" --install-option="--library-path=/usr/lib/graphviz/"
You can refer to this link if you still have any issues with pygraphviz.
Thanks !!
Hi madhusudhan_s ,
Your suggestion is work. Ubuntu 16.04 python 3.5.
I think the problem is mismatch library in pip wheel and ubuntu /usr/lib.
