Make Install Failed
Hi, everyone.
I failed to install ncsdk as described on start guide website. When I'm running "make install" I'm getting the following error:
CMake Error at cmake/Dependencies.cmake:99 (find_package):
By not providing "FindOpenCV.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "OpenCV", but
CMake did not find one.
Could not find a package configuration file provided by "OpenCV" with any
of the following names:
OpenCVConfig.cmake opencv-config.cmake
Add the installation prefix of "OpenCV" to CMAKE_PREFIX_PATH or set
"OpenCV_DIR" to a directory containing one of the above files. If "OpenCV"
provides a separate development package or SDK, be sure it has been
installed.
Call Stack (most recent call first):
CMakeLists.txt:46 (include)
-- Configuring incomplete, errors occurred!
See also "/opt/movidius/bvlc-caffe/build/CMakeFiles/CMakeOutput.log".
See also "/opt/movidius/bvlc-caffe/build/CMakeFiles/CMakeError.log".
make[1]: Entering directory '/opt/movidius/bvlc-caffe/build'
make[1]: *** No rule to make target 'all'。 停止。
make[1]: Leaving directory '/opt/movidius/bvlc-caffe/build'
Installing caffe…
make[1]: *** No rule to make target 'install'。 停止。
My configuration:
corf@corf-ThinkPad-E450:~/workspace/ncsdk$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.2 LTS
Release: 16.04
Codename: xenial
Same problem, the "make install" simply does not work…Frustrating…
More details here:
make[1]: Leaving directory `/opt/movidius/bvlc-caffe/build'
Installation failed. Error on line 485
Managed to install by changing to previous tag on git repo. Latest is v1.10.01.01, previous one is v1.10.00.03.
git checkout v1.10.00.03
then
make install
Regarding the make examples, is another story….
I successfully made it in a new installed Ubuntu 16.04 computer.
When I run make install, after about 10 minutes, the entire vm crashes on me with all sorts of colors. This is with Ubuntu 16.04 and v1.12
@fizzgig How much memory are you setting aside for the VM? Try using at least 2 GB for your VM RAM.
I'm at 2048 with 2 cpus. And 40gb ram. I'll try increasing to 4gb and see what happens.
@fizzgig Any luck with increasing the ram?
@Tome_at_Intel Increasing the ram had no effect. Still getting the same error. I've even tried previous tags from the repo.
@fizzgig Which VM software are you using and what error message do you receive when the machine crashes?
@Tome_at_Intel I'm using VirtualBox 5.2.6 with Ubuntu 16.04. I've set the memory to 4gb from 2gb. Hard Drive space is 40gb.
I've also tried both the ICH9 and PIIX3 chip sets.
I"m not seeing any error. It's just crashing with a multi-color screen displaying with the screen resized to more of a rectangle shape. It looks like there may be text on the multi-color screen in multi-color/character built letters, but it's unreadable. It looks like it's just crashing the VM.
