mvNCCompile has problem with Dropout
I have a Tensorflow model saved, and I am trying to use
compilable frozen_model.pb -in conv_I_input -on dense_6/Softmax -o output
But I am getting the error below. Any idea how can I get rid of it?
Note: the model was originally defined by keras, but saved as frozen Tensorflow model!
Thanx in advance
Sandor
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py:766: DeprecationWarning: builtin type EagerTensor has no module attribute
EagerTensor = c_api.TFE_Py_InitEagerTensor(_EagerTensorBase)
/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead
if d.decorator_argspec is not None), _inspect.getargspec(target))
Traceback (most recent call last):
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1323, in _do_call
return fn(*args)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1302, in _run_fn
status, run_metadata)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/errors_impl.py", line 473, in exit
c_api.TF_GetCode(self.status.status))
tensorflow.python.framework.errors_impl.InvalidArgumentError: You must feed a value for placeholder tensor 'dropout_5/keras_learning_phase' with dtype bool
[[Node: dropout_5/keras_learning_phase = Placeholder[dtype=DT_BOOL, shape=, _device="/job:localhost/replica:0/task:0/device:CPU:0"]()]]
During handling of the above exception, another exception occurred:
File "/usr/local/bin/mvNCCompile", line 118, in
create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights)
File "/usr/local/bin/mvNCCompile", line 104, in create_graph
net = parse_tensor(args, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 276, in parse_tensor
res = outputTensor.eval(feed_dict={inputnode + ':0' : input_data})
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 570, in eval
return _eval_using_default_session(self, feed_dict, self.graph, session)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 4455, in _eval_using_default_session
return session.run(tensors, feed_dict)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 889, in run
run_metadata_ptr)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1120, in _run
feed_dict_tensor, options, run_metadata)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1317, in _do_run
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1336, in _do_call
raise type(e)(node_def, op, message)
Caused by op 'dropout_5/keras_learning_phase', defined at:
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 211, in parse_tensor
tf.import_graph_def(graph_def, name="")
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/importer.py", line 313, in import_graph_def
op_def=op_def)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 2956, in create_op
op_def=op_def)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 1470, in init
self._traceback = self._graph._extract_stack() # pylint: disable=protected-access
InvalidArgumentError (see above for traceback): You must feed a value for placeholder tensor 'dropout_5/keras_learning_phase' with dtype bool
It turned out that the problem is not only related to Dropout….
I seen
https://github.com/ardamavi/Intel-Movidius-NCS-Keras
where the same InvalidArgumentError was seen on the input layer…..
Anyone else seen this error?
Thanx
S&|
@sseres, The key to you issue is in this error statement:
Looks like your frozen model still has variables in it, which shouldn't be the case when performing inference on any mobile/embedded device. Here's a simple example network that uses dropout layer - https://github.com/ashwinvijayakumar/ncappzoo/tree/single-conv/tensorflow/single-conv.
At the time of writing this response, I haven't yet merged my image-classifier updates, so replace apps/image-classifier with https://github.com/ashwinvijayakumar/ncappzoo/tree/classifier-template/apps/image-classifier before following instructions on tensorflow/single-conv/README.md
Hi @AshwinVijayakumar,
Thanx for the response.
This is how I saved my model:
K.set_learning_phase(0)
K._LEARNING_PHASE = tf.constant(0)
file_name = 'orig_graph.pb'
saver = tf.train.Saver(tf.global_variables())
with tf.Session() as sess:
sess.run(tf.global_variables_initializer())
sess.run(tf.local_variables_initializer())
constant_graph = graph_util.convert_variables_to_constants(sess, sess.graph.as_graph_def(), ['dense_6/Softmax'])
graph_io.write_graph(constant_graph, '.', file_name, as_text=False)
Something I am doing wrong?
Thanx
S&|
p.s.: Just in case my model & the trained parameters are at
https://drive.google.com/open?id=1oJQIdpLn-wCjhARR6qxYlWwdyhHYcjy8
@sseres, looks like the model was built with Keras and then you use tenssorflow to convert all variable to constants. Can you check if Keras is creating a nn.dropout or layers.dropout layer for you? I am not sure if an how .convert_variables_to_constants deals with tensorflow.nn.dropout, but I do know that freeze_graph does not like this op/layer. i.e. it skips the dropout layer and leaves behind the placeholder (& it's variable).
Here's an example project that attempts to deal with this issue. It's a work in progress, so I can't prove this solution works perfectly (especially since NCSDK doesn't yet support placeholder_with_defaults).
https://github.com/ashwinvijayakumar/ncappzoo/commit/0ff421e2f7363a4b369f0bbf95fedfc4b1164720#diff-414bbfe1e572ab483afc57fb07263431
Some tips for debugging your model
Use https://github.com/tensorflow/tensorflow/blob/master/tensorflow/python/tools/import_pb_to_tensorboard.py to visualize your pb file, and check if you still see a placeholder with variable in the graph.
Update: freeze_graph uses .convert_variables_to_constants for converting variable to constants, but it also does other house cleaning tasks like removing device specific nodes (training related layers/ops).
