6573 Discussions
Make the examples Error! on NCS2 - [Error 7] Toolkit Error: USB Failure. Code: Error opening device
Weng__Wenwei
hi,
I have NCS2 plugged in ubuntu 16.04 (running natively), I got several errors when I'm doing "make examples".
****** WARNING: No Weights found. using filler weights ******
Fusing Pad and Convolution2D
Fusing BatchNorm and Scale after Convolution
Replacing BN with Bias&Scale
Fusing Permute and Flatten
Fusing Eltwise and Relu
Eliminate layers that have been parsed as NoOp
Evaluating input and weigths for each hw layer
#Network Input tensors ['data#24']
#Network Output tensors ['prob#38']
Blob generated
W: [         0] ncDeviceOpen:527    ncDeviceOpen() XLinkBootRemote returned error 3
Makefile:64: recipe for target 'profile' failed
make[2]: *** [profile] Error 255
make[2]: Leaving directory '/home/nicky/ncsdk/examples/caffe/AlexNet'
Makefile:12: recipe for target 'AlexNet' failed
make[1]: *** [AlexNet] Error 2
make[1]: Leaving directory '/home/nicky/ncsdk/examples/caffe'
Makefile:12: recipe for target 'caffe/.' failed
make: *** [caffe/.] Error 2
Please let me what to do.
Wenwei
Severine_H_Intel
Dear Wenwai,
are you using the NCSDK? NCS2 only works with OpenVINO, which can explain your error.
Best,
Severine
iqbal__fiaraz
that does look like th eoutput from ncsdk2  however we got a similar with openvino examples complie.  unplugged ncs2 and re plugged and it worked
BBi
same question here. I am using NCS2 with openvino.i try replugging it but it still doesnot work.
nikos1
Valued Contributor I
What version of the OpenVino SDK are you using?
R5 seems to have fixed most of the "Error opening device" NCS issues.
