6571 Discussões
Mobilenet-ssd caffe model gives NaN as output
Funcionário
1.792 Visualizações
Hi everyone, I am using mobilenet-ssd caffe model for detection. Using caffemodel and prototxt file from here : https://github.com/chuanqi305/MobileNet-SSD
Using the caffemodel and prototxt I was able to generate graph file without any error using mvNCCompile
But whenever I load my output after detection I see NAN in the output.
input_image = cv2.resize(input_image,(300,300), cv2.INTER_LINEAR) display_image = input_image height_crop = display_image.shape[0] width_crop = display_image.shape[1] input_image = input_image.astype(np.float32) input_image = np.subtract(input_image,127.5) input_image = np.multiply(input_image,0.007843) input_image = input_image.astype(np.float32) graph.LoadTensor(input_image, 'user object') out, userobj = graph.GetResult()
Any directions are appreciated , thank you .
12 Respostas
Funcionário
1.442 Visualizações
@hrsht.sarma I'm attempting to reproduce your issue, but I was unable to generate the graph file from the links you provided. Did you modify the prototxt file in any way? I tried removing the training and data layers but this did not work for me. If you performed any special steps, please let me know and I will try it again. Thanks.
Funcionário
1.442 Visualizações
@Tome_at_Intel isn't mobilenet-ssd supported in current release? I even can not compile the graph file.
Funcionário
1.442 Visualizações
I have following files :
prototxt: https://drive.google.com/file/d/1O11sw2AvG4RlG_JnzQSFodT9WTH7PKaQ/view?usp=sharing
caffemodel : https://drive.google.com/file/d/1d4Bfey6knTGCJtH5P_Q3WXT2J6pdCH6y/view?usp=sharing
I can make a graph file with following warning :
/usr/local/bin/ncsdk/Controllers/FileIO.py:52: UserWarning: You are using a large type. Consider reducing your data sizes for best performance
"Consider reducing your data sizes for best performance\033[0m")
Funcionário
1.442 Visualizações
@hrsht.sarma As I see you are using float32. Input tensor uses half precision (fp16) values.
I also had problem with generating the graph. Can you please share the command line you used with mvNCCompile?
Funcionário
1.442 Visualizações
mvNCCompile MobileNet_deploy.prototxt -w MobileNet_deploy.caffemodel -s 12
Funcionário
1.442 Visualizações
@georgievm_cms Using fp16 half precision , i get output of length 1001 but I dont understand how to interpret this output , thanks for your help. Do you have any hints ?
This is how my output looks like : [ -324.25,520.0,82.812,-1400.0,-425.5,-407.5,-705.5,-1011.5,-351.5,-555.5,1123.0,264.0,923.0,331.0,-677.5………]
Funcionário
1.442 Visualizações
@hrsht.sarma, why I got output of length 707 with the same caffe model you used. You only change the type to fp16 in the script above to get output of length 1001?
Funcionário
1.442 Visualizações
@hrsht.sarma, the weight and prototxt you used is not mobilenet ssd, but mobilenet. That is why you got 1001 results.
Funcionário
1.442 Visualizações
@xhuan28 @hrsht.sarma @Tome_at_Intel @georgievm_cms
There are now a few examples for SSD MobileNet in the ncappzoo
Look in the apps/video_object and caffe/SSD_MobileNet projects
Funcionário
1.442 Visualizações
@hrsht.sarma, To address your original question, if you look at the run.py code here: https://github.com/movidius/ncappzoo/tree/master/caffe/SSD_MobileNet you can see how to handle the NaN values in some of the network results.
Neal
Funcionário
1.442 Visualizações
Thanks , I am running mobilenet SSD now.
Funcionário
1.442 Visualizações
@neal_at_intel , @Tome_at_Intel But mobilenet-ssd‘s some layers output is nan when use the size of image larger than 300×300.
Issue: https://ncsforum.movidius.com/discussion/comment/1618/#Comment_1618
Responder
