Model - rfcn resnet 101
Bhargavan__Aiswarya
“[ WARNING ] Model Optimizer removes pre-processing block of the model which resizes image keeping aspect ratio. The Inference Engine does not support dynamic image size so the Intermediate Representation file is generated with the input image size of a fixed size.
Specify the "--input_shape" command line parameter to override the default shape which is equal to (600, 600).
The Preprocessor block has been removed. Only nodes performing mean value subtraction and scaling (if applicable) are kept.
[ ERROR ]  Exception occurred during running replacer "ObjectDetectionAPIDetectionOutputReplacement" (<class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIDetectionOutputReplacement'>): Found the following nodes '[]' with name 'proposals' but there should be exactly 1. Looks like ObjectDetectionAPIProposalReplacement replacement didn't work.”
Any suggestion to solve this error?
Shubha_R_Intel
Dear Bhargavan, Aiswarya,
Please open the attached zip file and use faster_rcnn_support_api_v1.13.json for the --tensorflow_use_custom_operations_config switch.
For https://github.com/tensorflow/models  use Commit ID: 6fc642d423648f6a932673f0b3c07e40268c979f
Basically use an update prior to May 31 and it will work.
Shubha
