I'd like to run some official OpenVINO samples (like this), but I always get the following error:
from openvino.inference_engine import IECore
ModuleNotFoundError: No module named 'openvino'
Why do I get this error?
I'm testing on Raspberry Pi 3B with Movidius Neural Compute Stick 1 (NCS1).
The OS is Raspberry Pi OS 32-bit (Legacy) Buster (because Bullseye doesn't support NCS1).
OpenVINO Version is l_openvino_toolkit_runtime_raspbian_p_2020.3.194.tgz,
which is the last version that can support NCS1.
Here's the procedure to set up my OpenVINO:
sudo mkdir -p /opt/intel/openvino
mkdir ~/download
cd ~/download
wget https://storage.openvinotoolkit.org/repositories/openvino/packages/2020.3/l_openvino_toolkit_runtime_raspbian_p_2020.3.194.tgz
sudo tar -xf l_openvino_toolkit_runtime_raspbian_p_2020.3.194.tgz --strip 1 -C /opt/intel/openvino
echo "source /opt/intel/openvino/bin/setupvars.sh" >> ~/.bashrc
sudo usermod -a -G users "$(whoami)"
sh /opt/intel/openvino/install_dependencies/install_NCS_udev_rules.sh
cd /opt/intel/openvino/deployment_tools/inference_engine/samples/python/
pip install -r requirements.txt
I think I followed the installation instruction.
Is there any way to check if my OpenVINO installation is correct?
Hi IanHacker,
I encountered the same error when importing IECore with l_openvino_toolkit_runtime_raspbian_p_2020.3.194.tgz.
Please use l_openvino_toolkit_runtime_raspbian_p_2020.3.355.tgz to solve this issue.
Wan
Hi IanHacker,
Wan
Hi Wan,
Yes, it works!
Thank you verrry much!
You can close this thread, if you want.
I love Intel!
Ian
Hi IanHacker,
Thanks for your support.
This thread will no longer be monitored since the issue has been resolved. If you need additional information, please submit a new question and we'll be happy to help.
Wan
