Multiple FPGAs with OpenVINO
jliu32
Suppose I have more than one Arria 10 Development Kits installed on the motherboard, how can I select which board to use for a given inference request?
Monique_J_Intel
Hi James,
To use multiple FPGAs you can do so by specifying the KEY_DEVICE_ID and the number. In this example I have 2 FPGAs:
ExecutableNetwork  excutable_network1 = plugin.LoadNetwork(network, {InferenceEngine::PluginConfigParams::KEY_DEVICE_ID, "0"});
ExecutableNetwork  excutable_network1 = plugin.LoadNetwork(network, {InferenceEngine::PluginConfigParams::KEY_DEVICE_ID, "1"});
Then from here you can create the infer request for each FPGA respectively.
Kind Regards,
Monique Jones
jliu32
Hi Monique,
   Thanks for the prompt reply. Does device id "x" in OpenVINO map to "aclx" seen by aocl then?
James
Monique_J_Intel
Hi James,
Yes, that is correct.
Kind Regards,
Monique Jones
Shawn_S_Intel
The code that Monique specified appears to require double curly braces for compilation:
ExecutableNetwork executable_network = plugin.LoadNetwork(network, {{InferenceEngine::PluginConfigParams::KEY_DEVICE_ID, "0"}});
