- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I am trying to run the C++ Interactive-face-detection-demo in Ubuntu 16.04 in Intel dev-cloud using the cpp reference samples.
In the cpp interactive-face-detection reference sample they are running by providing all models at a time using below command.
./face_detector -i $INPUT_FILE -no_wait \ -m models/Transportation/object_detection/face/pruned_mobilenet_reduced_ssd_shared_weights/dldt/face-detection-adas-0001${FPEXT}.xml \ -m_hp models/Transportation/object_attributes/headpose/vanilla_cnn/dldt/head-pose-estimation-adas-0001${FPEXT}.xml \ -m_ag models/Retail/object_attributes/age_gender/dldt/age-gender-recognition-retail-0013${FPEXT}.xml \ -m_em models/Retail/object_attributes/emotions_recognition/0003/dldt/emotions-recognition-retail-0003${FPEXT}.xml \ -d $DEVICE -d_hp $DEVICE -d_ag $DEVICE -d_em $DEVICE \ -o $OUTPUT_FILE
It is working fine. But If i tried to run the above sample with only face-detection model with the below command.
./face_detector -i $INPUT_FILE -no_wait \ -m models/Transportation/object_detection/face/pruned_mobilenet_reduced_ssd_shared_weights/dldt/face-detection-adas-0001-fp16.xml -d MYRIAD
I am getting the below error ..
[ ERROR ] Cannot make shared blob! The blob type cannot be used to store objects of current precision
/opt/intel/openvino_2019.1.094/deployment_tools/inference_engine/include/details/ie_exception_conversion.hpp:71
Appreciated for any reply on this issue.
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Ranganadh,
I tested the interactive face detection demo just using the face detection model and it work fine with the following command on OpenVINO 2019 R3.1. I'm not sure if you can upgrade your version on the Intel DevCloud, however, you should be able find the answer on the Intel DevCloud support forum.
./interactive_face_detection_demo -i cam -m /opt/intel/openvino/deployment_tools/open_model_zoo/tools/downloader/intel/face-detection-adas-0001/FP16/face-detection-adas-0001.xml -d MYRIAD
Jesus
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Jesus,
Thank you so much for your quick response.
I m trying to run with flag -o , for storing output in a file in disk, using the below command
./interactive_face_detection_demo -i ~/smart_video_validation/iot-devcloud/smart-video-workshop/advanced-video-analytics/cpp/faces-recognition-walking-and-pause.mp4 -m ~/smart_video_validation/iot-devcloud/smart-video-workshop/advanced-video-analytics/cpp/models/Transportation/object_detection/face/pruned_mobilenet_reduced_ssd_shared_weights/dldt/face-detection-adas-0001.xml -o ~/results/out.mp4
InferenceEngine:
API version ............ 1.6
Build .................. custom_releases/2019/R1_c9b66a26e4d65bb986bb740e73f58c6e9e84c7c2
[ INFO ] Parsing input parameters
[ INFO ] Reading input
OpenCV: FFMPEG: tag 0x56555949/'IYUV' is not supported with codec id 14 and format 'mp4 / MP4 (MPEG-4 Part 14)'
[mp4 @ 0x51957c0] Could not find tag for codec rawvideo in stream #0, codec not currently supported in container
(interactive_face_detection_demo:43262): GStreamer-CRITICAL **: gst_element_make_from_uri: assertion 'gst_uri_is_valid (uri)' failed.
Please find the attached screenshot for good understanding about issue.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Ranganadh,
I was able to save the inference results to a video file (mp4) with the -o flag on the example without any issues on OpenVINO 2019 R3.1. The issue may be related to the OpenVINO 2019 R1 or the configuration of the Intel DevCloud. I recommend contacting the Intel DevCloud support for this issue.
https://colfaxresearch.com/discussion/forum/colfax-cluster/
Jesus
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
