NCS installation Error
员工
1,483 次查看
I just tried to install MDK on ubuntu16.04 LTS.
But I got an error during the step2 "make install"
It seems that I need to add "-fPIC" to the CFLAGS, but I don't know where to add it. Anybody help me please?
make[1]: Entering directory '/opt/movidius/ssd-caffe/build'
make[2]: Entering directory '/opt/movidius/ssd-caffe/build'
make[3]: Entering directory '/opt/movidius/ssd-caffe/build'
make[3]: Leaving directory '/opt/movidius/ssd-caffe/build'
[ 2%] Built target proto
[ 2%] Linking CXX shared library ../../lib/libcaffe.so
/usr/bin/ld: /usr/local/lib/libpython3.6m.a(object.o): relocation R_X86_64_32 against .rodata.str1.1' can not be used when making a shared object; recompile with -fPIC /usr/local/lib/libpython3.6m.a: error adding symbols: Bad value collect2: error: ld returned 1 exit status src/caffe/CMakeFiles/caffe.dir/build.make:3058: recipe for target 'lib/libcaffe.so.1.0.0-rc3' failed make[3]: *** [lib/libcaffe.so.1.0.0-rc3] Error 1 make[3]: Leaving directory '/opt/movidius/ssd-caffe/build' CMakeFiles/Makefile2:272: recipe for target 'src/caffe/CMakeFiles/caffe.dir/all' failed make[2]: *** [src/caffe/CMakeFiles/caffe.dir/all] Error 2 make[2]: Leaving directory '/opt/movidius/ssd-caffe/build' Makefile:127: recipe for target 'all' failed make[1]: *** [all] Error 2 make[1]: Leaving directory '/opt/movidius/ssd-caffe/build' Installing caffe... make[1]: Entering directory '/opt/movidius/ssd-caffe/build' make[2]: Entering directory '/opt/movidius/ssd-caffe/build' make[3]: Entering directory '/opt/movidius/ssd-caffe/build' make[3]: Leaving directory '/opt/movidius/ssd-caffe/build' [ 2%] Built target proto make[3]: Entering directory '/opt/movidius/ssd-caffe/build' make[3]: Leaving directory '/opt/movidius/ssd-caffe/build' make[3]: Entering directory '/opt/movidius/ssd-caffe/build' [ 2%] Linking CXX shared library ../../lib/libcaffe.so /usr/bin/ld: /usr/local/lib/libpython3.6m.a(object.o): relocation R_X86_64_32 against.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
Installation failed. Error on line 498
0 项奖励
3 回复数
员工
1,233 次查看
@FREEMAN123 Are you installing the MDK (Myriad Developerment Kit) or Neural Compute SDK?
0 项奖励
员工
1,233 次查看
@Tome_at_Intel
Oh, it's NCSDK, sorry I made a mistake.
I just successfully installed the NCSDK by recompiling my python3. But I think it's because the PYTHONTEST was skipped that made the installation successful.
Thanks very much!
0 项奖励
员工
1,233 次查看
@Tome_at_Intel I seem to be running into a similar issue. When trying to install the ncsdk (1.12) on Ubuntu 16.04, I get an error on line 498 (the following);
/usr/bin/ld: /usr/local/lib/libpython3.6m.a(object.o): relocation R_X86_64_32 against `PyBaseObject_Type' can not be used when making a shared object; recompile with -fPIC
Previously, I got the same error, except instead of "PyBaseObject_Type", I got ".rodata.str1.1" (same as the error discussed here). I then tried recompiling python 3.6 to recompile with -fpic, modifying the makefile, changing the configure command to include "--enable_shared", and yet I still end up not being able to complete the installation (the error changed to mention "PyBaseObject_Type". Not sure what the "PYTHONTEST" comment is about.
0 项奖励
回复
