6577 Discussions
NCS wih NCSDK2: no device can be found
My device is Intel® Movidius™ Neural Compute Stick.I both installed openVINO and NCSSDK2 on ubuntu 16.04.I installed fllow
OpenVINO:https://software.intel.com/en-us/articles/OpenVINO-Install-Linux#Movidius-steps
NCSSDK2: https://movidius.github.io/ncsdk/ncs.html
both can't work,the information is as follows.
1. openVINO
action@action:~/code/caffe/caffe_tool$ ./classify_openvino.sh
[setupvars.sh] OpenVINO environment initialized
Run Inference Engine classification sample
[ INFO ] InferenceEngine:
API version ………… 1.4
Build ……………… 19154
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ] /home/action/code/caffe/caffe_tool/horse1.BMP
[ INFO ] Loading plugin
API version ............ 1.5 Build .................. 19154 Description ....... myriadPlugin
[ INFO ] Loading network files:
/home/action/code/caffe/caffe_tool/optmi_FP16/caffenet_train_iter_2500.xml
/home/action/code/caffe/caffe_tool/optmi_FP16/caffenet_train_iter_2500.bin
[ INFO ] Preparing input blobs
[ WARNING ] Image is resized from (640, 480) to (224, 224)
[ INFO ] Batch size is 1
[ INFO ] Preparing output blobs
[ INFO ] Loading model to the plugin
[ ERROR ] Can not init USB device: NC_DEVICE_NOT_FOUND
2.NCSSDK2
action@action:~/code/ncs/ncsdk/examples/apps/hello_ncs_py$ python2 hello_ncs.py
D: [ 0] ncDeviceCreate:308 ncDeviceCreate index 0
Error - no NCS devices detected, verify an NCS device is connected.
action@action:~/code/ncs/ncsdk/examples/apps/hello_ncs_py$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 8087:0a2b Intel Corp.
Bus 001 Device 003: ID 17ef:6019 Lenovo
Bus 001 Device 005: ID 046d:c31c Logitech, Inc. Keyboard K120
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Hi @yangxiu123321
It looks like your device is not being detected by your system. Are you running Ubuntu as a Virtual Machine?
Have you tried plugging the NCS into another USB port or another computer?
Sahira
I have the same issue with two different new v2 sticks. Using Ubuntu 16.04.5 on a Dell i7 (nothing virtual). Tried to go through an usb hub but didn't work
I tried the same stick with Stretch. It is not recognized by the OS.
Hi @sudhirkshirsagar
The software kit that is compatible with the NCS2 is OpenVINO, not the NCSDK. Here is the installation page for OpenVINO. For reference, the forums for OpenVINO is here
But I do want to make sure that your device is recognizing the NCS2. Can you run lsusb and make sure that the NCS2 is listed?
Sahira
WDomo
sahira I am really struggling with the same problem. Latest openvino brand new movidius
lsusb doesn't see the id but the details are there on USB-devices
