NCS2 Error on Windows 10
Tsin__Ross
OpenVINO version : 2019 R1
Info from command line window:
Inference time: 4149.96 ms
F: [xLink] [         0] dispatcherEventReceive:318 Duplicate id detected.
WinUsb_WritePipe: System err 22
WinUsb_WritePipe failed with error:=0
WinUsb_ReadPipe: System err 22
E: [xLink] [         0] dispatcherEventSend:889    E: [xLink] [         0] dispatcherEventReceive:308 dispatcherEventReceive() Read failed -2 | event 00000004A95FFB38 USB_READ_REL_REQ
Write failed header -2 | event USB_WRITE_REQ
E: [xLink] [         0] eventReader:256    eventReader stoppedbox : 151
WinUsb_WritePipe failed with error:=22
, 202
, 130E: [xLink] [         0] dispatcherEventSend:889       , Write failed header -2 | event USB_READ_REL_RESP
181
Analysis Time is :25442.00ms.
..\thirdparty\movidius\XLink\shared\XLink.c:1183:
 Assertion Failed: link != NULL
E: [ncAPI] [         0] ncFifoDestroy:2888 Failed to write to fifo before deleting it!
..\thirdparty\movidius\XLink\shared\XLink.c:1124:
..\thirdparty\movidius\XLink\shared\XLink.c:1395:
Execution successful,
and the inference result is wrong.
Kenneth_C_Intel
Hi have you been able to run the samples to verify that the installation was successful on the NCS2 device?
Tsin__Ross
It seems caused by the debugging thing.
forget about it.
Catastrophe
Hi!
I am trying to solve the following errors that you have previously encountered.
May I ask if you were able to find the cause of this error?
Thank you!
Tsin__Ross
Hi Kenneth,
This time, I run the object_detection_sample_ssd sample on (Raspberry Pi + NCS2) seems OK, and I then tried Tiny Yolo V3, but did not work.
I dump the output data, they are:
anchor :0
x:
0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
y:
w:
1.36816    -0.402344    -0.88623    -0.827148    -0.226074    -0.738281    -0.64209    -0.625    -0.640625    -1.18652    -1.08301    -1.11035    -1.32227    0.0644531    -0.563965    -1.76367    -2.33008    -3.30664    -1.3457    -0.339844    -0.850586    -2.29492    -3.09961    -1.9043    -0.520508    -1.33008    -0.314941    -4.35938    -4.90625    -1.44238    -1.37793    -0.937988    1.56348    -0.922363    -2.29102    -1.81836    -0.118164    -2.16797    -2.4082    1.42773    -1.63184    -2.33398    -0.345703    -0.640625    1.54004    -0.181641    -2.52539    -4.31641    -2.23633    -1.44629    -2.95703    -3.14258    0.131348    -5.03516    -5.78906    -1.48438    -1.08008    -0.614746    -0.150879    -2.08203    -3.46094    -3.00977    -3.81641    -3.07031    -1.99805    -2.23633    -5.67969    -2.51758    -1.63867    -1.02637    0.535645    -0.612305    0.258789    -1.66992    -1.36133    -2.75195    -2.55664    -2.23828    -2.04883    -4.23828    -1.41895    -1.86426    0.744141    -1.91797    -1.45996    -2.6582    -0.793945    -1.11035    -3.58008    -2.12305    -1.87988    -1.72852    -3.94922    -2.89062    -1.21875    -2.67188    -3.29883    -5.50391    -2.36328    0.0537109    -0.046875    -4.66016    -3.38672    -2.26953    -0.540039    -3.9375    -0.99707    -1.96973    -3.64648    -2.91602    -3.33203    -1.80762    2.75195    -0.546387    -3.69922    -3.34375    -3.32812    -0.429688    -1.18555    0.345703    -1.48047    -0.93457    -0.780762    0.121582    -1.17285    -1.05273    -0.600586    -3.28125    -2.73828    -2.69727    -0.871582    -0.950195    1.46191    1.37891    1.46094    0.624023    -0.753418    -3.04492    -2.04688    -0.859863    -1.5791    -2.00195    -2.83594    -1.02539    -3.18359    -1.16504    -0.0527344    -1.20703    -1.38184    -2.92188    -2.57617    -1.81445    -0.785156    -1.15527    -2.23438    -3.18945    -1.63574    -1.44141    -2.76953    -2.83984    -3.65234    -3.63672    -3.35547    -2.25    -1.63086    -0.920898    -1.9707    -1.71875    -1.44629
h:
1.66504    0.0957031    0.152832    -0.518066    -0.84082    -1.76758    -0.903809    -0.019043    -0.170898    -1.33105    -1.70508    -1.26953    -1.0957    0.175781    -0.867188    -1.63672    -1.75977    -2.54883    -1.13574    -0.814453    -1.86523    -2.39453    -3.55859    -2.37695    0.137207    -0.782715    0.289062    -4.99219    -4.35547    -1.22852    -1.23828    -0.390625    1.18359    -2.49805    -2.74414    -1.56152    -0.224121    -1.86133    -1.7666    1.64355    -3.0957    -1.69824    -0.0932617    -0.568848    1.88672    1.23926    -1.99414    -3.84766    -2.33398    -1.3125    -1.27051    -1.80176    0.192383    -3.85547    -3.72461    0.600586    0.529297    0.0991211    1.26367    -0.550781    -2.31055    -1.75879    -2.18164    -1.34082    -1.00195    -1.91602    -4.01172    -1.22559    -0.481445    0.274414    1.75    0.0507812    1.44531    -0.735352    -0.676758    -3.4082    -2.29883    -1.7373    -2.01367    -2.37891    -0.740723    -1.41602    1.53516    0.412109    0.531738    -0.774414    0.361816    -0.172852    -3.10547    -1.90137    -1.42188    -1.13184    -2.18555    -2.5    0.318359    0.0493164    -0.896973    -3.32422    -0.320801    1.98828    0.97168    -2.38477    -1.62793    -1.49414    -0.0253906    -1.84961    0.342285    0.620117    -0.793945    -1.20996    -2.25781    -0.433105    3.25781    -0.720215    -1.44043    -0.920898    -1.96777    0.1875    0.634277    2.16016    1.10059    1.35645    1.0166    0.654785    0.23584    0.343262    1.03223    -0.849121    -0.796875    -1.74316    0.0942383    0.0400391    1.95508    2.5293    2.28906    2.06445    0.813965    -0.46875    0.0976562    0.251465    -1.81738    -1.53223    -2.06445    -0.453125    -1.86133    -0.433105    0.306641    -0.456055    -0.768555    -1.79688    -1.07812    0.043457    0.422852    -1.07324    -2.14258    -2.01367    -1.35449    -0.530762    -0.691895    -1.21289    -1.60645    -1.45215    -1.79883    -1.17969    -0.639648    -0.302734    -1.74219    -2.08984    -1.38086
confidence::
0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    1    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0    0
class possibility:
 anchor :1
x:
y:
w:
-0.725098    -0.383789    -0.0551758    -0.0268555    0.443848    0.368164    -0.812988    -1.85156    -0.885254    -0.462891    -0.284668    -1.26562    -0.401855    -1.25879    0.819824    1.33691    0.141602    -0.217773    0.680664    -0.949219    -1.73535    -0.870605    -1.21582    -0.39209    0.276367    -0.261719    -1.33203    -1.51855    0.195801    0.0805664    -0.338867    -0.700684    -0.917969    0.0249023    -0.700684    -0.592285    0.913086    0.0927734    -1.18848    -1.60547    -0.69873    0.0297852    0.457031    0.382324    -0.141113    -1.00488    -0.419434    -0.0629883    1.36523    1.46191    0.114258    -2.12109    -1.375    -1.67969    -0.868652    -0.177246    0.208984    -0.170898    -1.00195    0.196289    -0.0737305    -0.444824    -0.597656    -1.4873    -1.94336    -2.73438    -2.11328    -0.812988    -0.291992    -0.371582    -0.696289    -0.342773    0.629883    -0.130371    -1.27832    -0.916992    -1.42383    -1.78418    -1.93555    -1.08105    0.980469    1.08887    1.40527    -0.929688    0.328125    0.187012    -0.593262    -1.02637    -0.334961    -0.360352    -1.62793    -0.973633    1.3584    1.3291    1.07422    1.06152    -0.518555    -0.562012    0.177246    -0.0810547    0.606445    0.00537109    -0.0649414    -0.758789    -0.205078    2.32422    1.74805    1.4209    1.22656    -0.104492    0.106445    0.598633    0.59082    0.775879    -1.15625    -0.159668    -1.32129    -0.10498    2.57422    1.39453    0.48584    0.925781    -0.490723    0.637695    1.54004    0.889648    -0.577637    -1.33203    -0.991699    -1.76953    0.167969    2.75586    1.97266    1.26855    0.401855    -0.586426    0.974609    0.96582    0.550293    0.126953    0.137207    -0.619629    -1.27344    -0.597168    0.974609    1.25    2.02734    2.27148    0.516602    0.217773    0.335449    0.666016    0.678223    0.890137    0.42627    -0.551758    -1.66406    -1.06152    -0.571289    -0.880859    -1.4082    -1.41895    -1.53027    -0.71875    -0.65332    -0.624023    -0.454102    -0.271973    0.13623
h:
-0.605469    -0.270996    0.0507812    -0.249023    0.0844727    0.0888672    -0.927246    -2.07812    -1.11426    -0.57959    -0.486816    -0.739746    -0.299316    -0.862305    1.6543    1.92773    0.674805    0.57959    1.42676    -0.223145    -0.925293    -0.110352    -0.560059    -0.111328    1.16699    -0.287598    -0.29541    -1.0293    -0.161621    0.29834    0.912109    0.34082    -0.634277    0.791504    0.0170898    -0.399414    0.959961    0.824707    -1.13281    -0.874023    -0.469727    -0.229004    0.995117    1.63867    1.02637    -1.06934    -0.272461    -0.236328    0.898438    1.49805    0.818848    -1.95117    -1.43164    -1.99121    -0.994629    0.288574    1.40918    0.900391    -0.521973    0.0732422    -0.530762    -0.955078    -0.623047    -0.777344    -2.05859    -3.25391    -2.47852    -0.894043    0.199219    0.563965    0.043457    0.34082    0.935547    -0.0913086    -1.28223    -0.572266    -0.741699    -1.63086    -2.48633    -1.40332    0.66748    1.49902    1.80078    -1.09766    0.778809    0.795898    -0.208984    -0.87793    -0.283691    0.200195    -1.31055    -1.29688    0.692383    1.0293    0.57959    0.666016    -0.730957    -0.216309    0.602539    -0.428711    0.165527    -0.348145    0.174316    -0.578125    -0.865234    1.05957    0.995117    1.08105    0.844727    -0.150879    0.388672    0.693359    0.197754    0.623047    -1.52441    -0.196289    -1.26855    -1.03711    1.66895    1.0332    1.22852    0.987305    -0.401367    0.969727    1.3584    0.116699    -1.29688    -1.50488    -0.714844    -1.52051    -0.237305    1.70703    2.34961    1.94336    0.847656    -0.439941    1.04785    1.10156    0.251465    -0.250977    0.309082    -0.120117    -1.2041    -0.783203    0.0297852    0.954102    2.07227    2.23633    0.474609    0.300293    0.554199    0.8125    0.287109    0.664062    0.59082    -0.706543    -1.33691    -0.633789    0.14209    -0.446289    -1.15234    -1.19238    -1.19629    -0.149902    -0.29248    -0.702637    -0.322754    -0.0219727    0.353516
confidence::
class possibility:
 anchor :2
x:
y:
w:
-0.0214844    0.638672    0.277832    -0.806152    -0.875    -0.61084    -1.61523    -1.38867    -0.938477    -0.996094    -0.397461    -0.483398    0.100098    0.0751953    2.89648    2.27148    0.878906    0.54248    0.834961    -1.13867    -1.34961    -0.22998    0.195312    1.84961    2.84961    0.994629    -0.266602    0.192383    0.37207    0.11377    0.477539    0.00341797    -0.918457    -0.84375    -0.622559    0.508301    1.81934    1.38477    -0.15918    -1.10059    -0.234375    0.612793    0.791016    0.0976562    -0.175293    -0.658691    0.513184    -1.09473    -0.366699    0.67041    0.993652    -0.816406    -1.5    -1.21387    0.794434    1.62695    0.945801    0.0874023    0.334473    0.569336    -0.163574    -0.119629    0.253418    0.626953    -0.291992    -2.30859    -1.19141    1.12793    1.49316    0.34375    0.0200195    0.625488    0.771973    -0.0957031    -0.459473    -0.458984    -0.447266    -0.679199    -1.05469    1.24512    2.02148    0.198242    0.336426    -0.376465    1.28125    0.903809    0.313477    0.431152    0.682617    -0.0478516    -0.337891    -0.216797    1.74414    0.744141    -0.166992    0.495605    -0.289551    1.39453    1.41016    0.266602    0.526367    0.395508    0.594727    0.276855    -0.429199    0.871582    -0.050293    0.883301    1.55273    0.960449    1.85449    1.15918    -0.078125    0.620117    -0.663086    0.243164    -0.272949    -0.074707    1.93652    1.00391    1.09473    2.10547    0.881348    1.23047    0.761719    0.394531    -0.206055    -0.849609    -0.975586    -0.749023    1.58789    3.08594    1.9541    0.848145    0.356934    -0.212891    0.499023    0.52832    0.256836    -0.365234    -0.174805    -1.02148    -1.25391    0.817383    1.78711    1.36328    1.27637    1.97168    0.406738    0.0180664    0.38916    0.380371    -0.344727    -0.229492    -0.244629    -0.828125    -0.705566    -0.139648    0.127441    -0.293457    -0.980957    -0.770996    -0.623047    -0.333008    -0.414062    -0.916504    -0.845703    -0.608398    -0.321777
h:
-0.693359    0.217285    -0.512207    -1.24121    -0.93457    -0.526855    -1.625    -1.30762    -1.16992    -0.881348    -0.326172    -0.0810547    0.615234    -0.413086    2.11133    1.12598    -0.605957    -0.0786133    0.885742    -0.932129    -1.12109    -0.196289    -0.499023    1.13184    2.08008    1.12012    0.505859    0.418945    0.371582    -1.1543    -0.577637    -0.559082    -1.21973    0.0366211    -0.396484    -0.592285    0.743652    0.951172    0.0258789    -0.352539    0.510742    0.70459    0.432129    -0.279297    -0.713379    -0.610352    0.420898    -0.277832    0.236816    0.954102    1.22363    -0.492676    -1.47852    -0.779785    1.59473    2.30859    0.79541    -0.373047    -0.709961    -0.0786133    -0.355957    0.257324    0.757812    0.850586    -0.163574    -2.53711    -1.33203    1.40039    1.86719    0.0649414    -0.674316    -0.546875    -0.300781    -0.0859375    0.226074    0.256836    -0.236816    -0.396484    -1.42188    0.853516    1.44336    0.525879    -0.134766    -0.878418    0.367676    0.262695    0.361816    0.883789    0.985352    -0.000976562    -0.211426    0.0712891    1.99609    1.21191    0.478027    0.0380859    -0.286133    1.62598    1.52637    -0.131836    0.312988    0.37793    0.441895    0.318359    -0.19873    0.813477    0.422852    1.69531    1.80176    1.01074    1.7168    1.20703    -0.0986328    0.387695    -0.363281    -0.097168    -0.253906    0.191895    1.08398    0.729492    1.5791    2.11133    0.947266    0.876953    0.816895    0.382812    -0.512207    -0.458496    -0.964844    -0.700195    1.80859    1.92969    1.3125    1.19434    0.325195    -0.228027    0.534668    0.675293    0.461426    -0.583008    -0.0424805    -0.507812    -0.822266    0.905273    0.955078    0.0478516    0.821777    1.5    0.522949    0.541992    0.617188    0.319336    -0.608887    0.187012    -0.12793    -0.469238    -0.352051    -0.0610352    0.52832    -0.0976562    -0.943359    -0.51416    0.180176    0.631836    0.303223    -0.413574    -0.317383    -0.0766602    0.0791016
confidence::
class possibility:
looks like the logistic activation output all zeros.
Could you do me a favor to inspect this issue? Thank you.
Tsin__Ross
I also tried to remove the last layer to see what happen, but I got an error
The output blob size is not equal to the network output size: got 12168 expecting 11492
/opt/intel/openvino/inference_engine/include/details/ie_exception_conversion.hpp:71
