OpenVINO version : 2019 R1
Info from command line window:
Inference time: 4149.96 ms
[31mF: [xLink] [ 0] dispatcherEventReceive:318 Duplicate id detected.
[0m
WinUsb_WritePipe: System err 22
WinUsb_WritePipe failed with error:=0
WinUsb_ReadPipe: System err 22
[35mE: [xLink] [ 0] dispatcherEventSend:889 [35mE: [xLink] [ 0] dispatcherEventReceive:308 dispatcherEventReceive() Read failed -2 | event 00000004A95FFB38 USB_READ_REL_REQ
Write failed header -2 | event USB_WRITE_REQ
[0m
[0m
[35mE: [xLink] [ 0] eventReader:256 eventReader stoppedbox : 151
WinUsb_WritePipe failed with error:=22
, 202[0m
, 130[35mE: [xLink] [ 0] dispatcherEventSend:889 , Write failed header -2 | event USB_READ_REL_RESP
181
[0m
Analysis Time is :25442.00ms.
..\thirdparty\movidius\XLink\shared\XLink.c:1183:
Assertion Failed: link != NULL
[35mE: [ncAPI] [ 0] ncFifoDestroy:2888 Failed to write to fifo before deleting it![0m
..\thirdparty\movidius\XLink\shared\XLink.c:1124:
..\thirdparty\movidius\XLink\shared\XLink.c:1395:
Execution successful,
and the inference result is wrong.
連結已複製
Hi!
I am trying to solve the following errors that you have previously encountered.
[0m
May I ask if you were able to find the cause of this error?
Thank you!
Hi Kenneth,
This time, I run the object_detection_sample_ssd sample on (Raspberry Pi + NCS2) seems OK, and I then tried Tiny Yolo V3, but did not work.
I dump the output data, they are:
anchor :0
x:
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
y:
w:
1.36816 -0.402344 -0.88623 -0.827148 -0.226074 -0.738281 -0.64209 -0.625 -0.640625 -1.18652 -1.08301 -1.11035 -1.32227 0.0644531 -0.563965 -1.76367 -2.33008 -3.30664 -1.3457 -0.339844 -0.850586 -2.29492 -3.09961 -1.9043 -0.520508 -1.33008 -0.314941 -4.35938 -4.90625 -1.44238 -1.37793 -0.937988 1.56348 -0.922363 -2.29102 -1.81836 -0.118164 -2.16797 -2.4082 1.42773 -1.63184 -2.33398 -0.345703 -0.640625 1.54004 -0.181641 -2.52539 -4.31641 -2.23633 -1.44629 -2.95703 -3.14258 0.131348 -5.03516 -5.78906 -1.48438 -1.08008 -0.614746 -0.150879 -2.08203 -3.46094 -3.00977 -3.81641 -3.07031 -1.99805 -2.23633 -5.67969 -2.51758 -1.63867 -1.02637 0.535645 -0.612305 0.258789 -1.66992 -1.36133 -2.75195 -2.55664 -2.23828 -2.04883 -4.23828 -1.41895 -1.86426 0.744141 -1.91797 -1.45996 -2.6582 -0.793945 -1.11035 -3.58008 -2.12305 -1.87988 -1.72852 -3.94922 -2.89062 -1.21875 -2.67188 -3.29883 -5.50391 -2.36328 0.0537109 -0.046875 -4.66016 -3.38672 -2.26953 -0.540039 -3.9375 -0.99707 -1.96973 -3.64648 -2.91602 -3.33203 -1.80762 2.75195 -0.546387 -3.69922 -3.34375 -3.32812 -0.429688 -1.18555 0.345703 -1.48047 -0.93457 -0.780762 0.121582 -1.17285 -1.05273 -0.600586 -3.28125 -2.73828 -2.69727 -0.871582 -0.950195 1.46191 1.37891 1.46094 0.624023 -0.753418 -3.04492 -2.04688 -0.859863 -1.5791 -2.00195 -2.83594 -1.02539 -3.18359 -1.16504 -0.0527344 -1.20703 -1.38184 -2.92188 -2.57617 -1.81445 -0.785156 -1.15527 -2.23438 -3.18945 -1.63574 -1.44141 -2.76953 -2.83984 -3.65234 -3.63672 -3.35547 -2.25 -1.63086 -0.920898 -1.9707 -1.71875 -1.44629
h:
1.66504 0.0957031 0.152832 -0.518066 -0.84082 -1.76758 -0.903809 -0.019043 -0.170898 -1.33105 -1.70508 -1.26953 -1.0957 0.175781 -0.867188 -1.63672 -1.75977 -2.54883 -1.13574 -0.814453 -1.86523 -2.39453 -3.55859 -2.37695 0.137207 -0.782715 0.289062 -4.99219 -4.35547 -1.22852 -1.23828 -0.390625 1.18359 -2.49805 -2.74414 -1.56152 -0.224121 -1.86133 -1.7666 1.64355 -3.0957 -1.69824 -0.0932617 -0.568848 1.88672 1.23926 -1.99414 -3.84766 -2.33398 -1.3125 -1.27051 -1.80176 0.192383 -3.85547 -3.72461 0.600586 0.529297 0.0991211 1.26367 -0.550781 -2.31055 -1.75879 -2.18164 -1.34082 -1.00195 -1.91602 -4.01172 -1.22559 -0.481445 0.274414 1.75 0.0507812 1.44531 -0.735352 -0.676758 -3.4082 -2.29883 -1.7373 -2.01367 -2.37891 -0.740723 -1.41602 1.53516 0.412109 0.531738 -0.774414 0.361816 -0.172852 -3.10547 -1.90137 -1.42188 -1.13184 -2.18555 -2.5 0.318359 0.0493164 -0.896973 -3.32422 -0.320801 1.98828 0.97168 -2.38477 -1.62793 -1.49414 -0.0253906 -1.84961 0.342285 0.620117 -0.793945 -1.20996 -2.25781 -0.433105 3.25781 -0.720215 -1.44043 -0.920898 -1.96777 0.1875 0.634277 2.16016 1.10059 1.35645 1.0166 0.654785 0.23584 0.343262 1.03223 -0.849121 -0.796875 -1.74316 0.0942383 0.0400391 1.95508 2.5293 2.28906 2.06445 0.813965 -0.46875 0.0976562 0.251465 -1.81738 -1.53223 -2.06445 -0.453125 -1.86133 -0.433105 0.306641 -0.456055 -0.768555 -1.79688 -1.07812 0.043457 0.422852 -1.07324 -2.14258 -2.01367 -1.35449 -0.530762 -0.691895 -1.21289 -1.60645 -1.45215 -1.79883 -1.17969 -0.639648 -0.302734 -1.74219 -2.08984 -1.38086
confidence::
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
class possibility:
anchor :1
x:
y:
w:
-0.725098 -0.383789 -0.0551758 -0.0268555 0.443848 0.368164 -0.812988 -1.85156 -0.885254 -0.462891 -0.284668 -1.26562 -0.401855 -1.25879 0.819824 1.33691 0.141602 -0.217773 0.680664 -0.949219 -1.73535 -0.870605 -1.21582 -0.39209 0.276367 -0.261719 -1.33203 -1.51855 0.195801 0.0805664 -0.338867 -0.700684 -0.917969 0.0249023 -0.700684 -0.592285 0.913086 0.0927734 -1.18848 -1.60547 -0.69873 0.0297852 0.457031 0.382324 -0.141113 -1.00488 -0.419434 -0.0629883 1.36523 1.46191 0.114258 -2.12109 -1.375 -1.67969 -0.868652 -0.177246 0.208984 -0.170898 -1.00195 0.196289 -0.0737305 -0.444824 -0.597656 -1.4873 -1.94336 -2.73438 -2.11328 -0.812988 -0.291992 -0.371582 -0.696289 -0.342773 0.629883 -0.130371 -1.27832 -0.916992 -1.42383 -1.78418 -1.93555 -1.08105 0.980469 1.08887 1.40527 -0.929688 0.328125 0.187012 -0.593262 -1.02637 -0.334961 -0.360352 -1.62793 -0.973633 1.3584 1.3291 1.07422 1.06152 -0.518555 -0.562012 0.177246 -0.0810547 0.606445 0.00537109 -0.0649414 -0.758789 -0.205078 2.32422 1.74805 1.4209 1.22656 -0.104492 0.106445 0.598633 0.59082 0.775879 -1.15625 -0.159668 -1.32129 -0.10498 2.57422 1.39453 0.48584 0.925781 -0.490723 0.637695 1.54004 0.889648 -0.577637 -1.33203 -0.991699 -1.76953 0.167969 2.75586 1.97266 1.26855 0.401855 -0.586426 0.974609 0.96582 0.550293 0.126953 0.137207 -0.619629 -1.27344 -0.597168 0.974609 1.25 2.02734 2.27148 0.516602 0.217773 0.335449 0.666016 0.678223 0.890137 0.42627 -0.551758 -1.66406 -1.06152 -0.571289 -0.880859 -1.4082 -1.41895 -1.53027 -0.71875 -0.65332 -0.624023 -0.454102 -0.271973 0.13623
h:
-0.605469 -0.270996 0.0507812 -0.249023 0.0844727 0.0888672 -0.927246 -2.07812 -1.11426 -0.57959 -0.486816 -0.739746 -0.299316 -0.862305 1.6543 1.92773 0.674805 0.57959 1.42676 -0.223145 -0.925293 -0.110352 -0.560059 -0.111328 1.16699 -0.287598 -0.29541 -1.0293 -0.161621 0.29834 0.912109 0.34082 -0.634277 0.791504 0.0170898 -0.399414 0.959961 0.824707 -1.13281 -0.874023 -0.469727 -0.229004 0.995117 1.63867 1.02637 -1.06934 -0.272461 -0.236328 0.898438 1.49805 0.818848 -1.95117 -1.43164 -1.99121 -0.994629 0.288574 1.40918 0.900391 -0.521973 0.0732422 -0.530762 -0.955078 -0.623047 -0.777344 -2.05859 -3.25391 -2.47852 -0.894043 0.199219 0.563965 0.043457 0.34082 0.935547 -0.0913086 -1.28223 -0.572266 -0.741699 -1.63086 -2.48633 -1.40332 0.66748 1.49902 1.80078 -1.09766 0.778809 0.795898 -0.208984 -0.87793 -0.283691 0.200195 -1.31055 -1.29688 0.692383 1.0293 0.57959 0.666016 -0.730957 -0.216309 0.602539 -0.428711 0.165527 -0.348145 0.174316 -0.578125 -0.865234 1.05957 0.995117 1.08105 0.844727 -0.150879 0.388672 0.693359 0.197754 0.623047 -1.52441 -0.196289 -1.26855 -1.03711 1.66895 1.0332 1.22852 0.987305 -0.401367 0.969727 1.3584 0.116699 -1.29688 -1.50488 -0.714844 -1.52051 -0.237305 1.70703 2.34961 1.94336 0.847656 -0.439941 1.04785 1.10156 0.251465 -0.250977 0.309082 -0.120117 -1.2041 -0.783203 0.0297852 0.954102 2.07227 2.23633 0.474609 0.300293 0.554199 0.8125 0.287109 0.664062 0.59082 -0.706543 -1.33691 -0.633789 0.14209 -0.446289 -1.15234 -1.19238 -1.19629 -0.149902 -0.29248 -0.702637 -0.322754 -0.0219727 0.353516
confidence::
class possibility:
anchor :2
x:
y:
w:
-0.0214844 0.638672 0.277832 -0.806152 -0.875 -0.61084 -1.61523 -1.38867 -0.938477 -0.996094 -0.397461 -0.483398 0.100098 0.0751953 2.89648 2.27148 0.878906 0.54248 0.834961 -1.13867 -1.34961 -0.22998 0.195312 1.84961 2.84961 0.994629 -0.266602 0.192383 0.37207 0.11377 0.477539 0.00341797 -0.918457 -0.84375 -0.622559 0.508301 1.81934 1.38477 -0.15918 -1.10059 -0.234375 0.612793 0.791016 0.0976562 -0.175293 -0.658691 0.513184 -1.09473 -0.366699 0.67041 0.993652 -0.816406 -1.5 -1.21387 0.794434 1.62695 0.945801 0.0874023 0.334473 0.569336 -0.163574 -0.119629 0.253418 0.626953 -0.291992 -2.30859 -1.19141 1.12793 1.49316 0.34375 0.0200195 0.625488 0.771973 -0.0957031 -0.459473 -0.458984 -0.447266 -0.679199 -1.05469 1.24512 2.02148 0.198242 0.336426 -0.376465 1.28125 0.903809 0.313477 0.431152 0.682617 -0.0478516 -0.337891 -0.216797 1.74414 0.744141 -0.166992 0.495605 -0.289551 1.39453 1.41016 0.266602 0.526367 0.395508 0.594727 0.276855 -0.429199 0.871582 -0.050293 0.883301 1.55273 0.960449 1.85449 1.15918 -0.078125 0.620117 -0.663086 0.243164 -0.272949 -0.074707 1.93652 1.00391 1.09473 2.10547 0.881348 1.23047 0.761719 0.394531 -0.206055 -0.849609 -0.975586 -0.749023 1.58789 3.08594 1.9541 0.848145 0.356934 -0.212891 0.499023 0.52832 0.256836 -0.365234 -0.174805 -1.02148 -1.25391 0.817383 1.78711 1.36328 1.27637 1.97168 0.406738 0.0180664 0.38916 0.380371 -0.344727 -0.229492 -0.244629 -0.828125 -0.705566 -0.139648 0.127441 -0.293457 -0.980957 -0.770996 -0.623047 -0.333008 -0.414062 -0.916504 -0.845703 -0.608398 -0.321777
h:
-0.693359 0.217285 -0.512207 -1.24121 -0.93457 -0.526855 -1.625 -1.30762 -1.16992 -0.881348 -0.326172 -0.0810547 0.615234 -0.413086 2.11133 1.12598 -0.605957 -0.0786133 0.885742 -0.932129 -1.12109 -0.196289 -0.499023 1.13184 2.08008 1.12012 0.505859 0.418945 0.371582 -1.1543 -0.577637 -0.559082 -1.21973 0.0366211 -0.396484 -0.592285 0.743652 0.951172 0.0258789 -0.352539 0.510742 0.70459 0.432129 -0.279297 -0.713379 -0.610352 0.420898 -0.277832 0.236816 0.954102 1.22363 -0.492676 -1.47852 -0.779785 1.59473 2.30859 0.79541 -0.373047 -0.709961 -0.0786133 -0.355957 0.257324 0.757812 0.850586 -0.163574 -2.53711 -1.33203 1.40039 1.86719 0.0649414 -0.674316 -0.546875 -0.300781 -0.0859375 0.226074 0.256836 -0.236816 -0.396484 -1.42188 0.853516 1.44336 0.525879 -0.134766 -0.878418 0.367676 0.262695 0.361816 0.883789 0.985352 -0.000976562 -0.211426 0.0712891 1.99609 1.21191 0.478027 0.0380859 -0.286133 1.62598 1.52637 -0.131836 0.312988 0.37793 0.441895 0.318359 -0.19873 0.813477 0.422852 1.69531 1.80176 1.01074 1.7168 1.20703 -0.0986328 0.387695 -0.363281 -0.097168 -0.253906 0.191895 1.08398 0.729492 1.5791 2.11133 0.947266 0.876953 0.816895 0.382812 -0.512207 -0.458496 -0.964844 -0.700195 1.80859 1.92969 1.3125 1.19434 0.325195 -0.228027 0.534668 0.675293 0.461426 -0.583008 -0.0424805 -0.507812 -0.822266 0.905273 0.955078 0.0478516 0.821777 1.5 0.522949 0.541992 0.617188 0.319336 -0.608887 0.187012 -0.12793 -0.469238 -0.352051 -0.0610352 0.52832 -0.0976562 -0.943359 -0.51416 0.180176 0.631836 0.303223 -0.413574 -0.317383 -0.0766602 0.0791016
confidence::
class possibility:
looks like the logistic activation output all zeros.
Could you do me a favor to inspect this issue? Thank you.
Kenneth Craft (Intel) wrote:Hi have you been able to run the samples to verify that the installation was successful on the NCS2 device?
I also tried to remove the last layer to see what happen, but I got an error
The output blob size is not equal to the network output size: got 12168 expecting 11492
/opt/intel/openvino/inference_engine/include/details/ie_exception_conversion.hpp:71
