NCS2 MYRIAD dlls and dependencies for inference
Gouveia__César
I'm using NCS2 on a Windows 10 OpenVINO environment. I have already tested and installed the Movidius_VSC_Device.inf file and runned your test script and all went ok. However I want to be able to use the NCS2 stick on my own solution, which uses the OpenVINO C++ API, what are the dlls and dependencies required to change the target device from CPU to MYRIAD and run inference using the stick?
César.
MAURICIOAL_R_Intel
Thank you for reaching out.
To use the Intel Neural Compute Stick 2 for inference, you will need to add: -d MYRIAD at the end of your command code.
Also, you must update several environment variables before you can compile and run OpenVINO™ applications. Open the Command Prompt, and run the setupvars.bat batch file to temporarily set your environment variables:
                    cd C:\Program Files (x86)\IntelSWTools\openvino\bin\
                     setupvars.bat
Mauricio R.
Gouveia__César
Hi Mauricio thank for your response,
I don't want to run through Intel Solution, I want to run using my solution and your C++ API, so I need to know which dlls to import, which dependencies are needed. I don't want to run setupvars.bat needer run the inference using the flag -MYRIAD. Instead of that I want to know which are the dlls and dependencies needed in order to be able to run your C++ API inference engine (using targetdevice::eMYRIAD).
César.
Gouveia__César
Putting the question in another way, imagine you want to gather all files needed to run movidius inference in a folder, what files do you need? dependencies, dlls, etc..
Gouveia__César
Can someone give me a little insight on this problem?
César.
MAURICIOAL_R_Intel
Hello Cesar,
I have not done this before, however, the C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\inference_engine\include directory contains the C++ header files for the inference engine as well as some for the VPU. Is there a particular reason why you need to build an application this way?
We also have the OpenVINO™ Deployment Manager which is supported on Windows in the latest release. The tool can create a deployment package to include your application, model and associated dependencies into a runtime package.
Mauricio R.
