NCS2 ncDeviceOpen error
I'm trying to check my NCS2 connection with Ubuntu 16.04 Virtual Machine. I have installed ncsdk2 from (https://github.com/movidius/ncsdk) and trying to run hello_ncs.py.
When I try to run this script while Movidius is connected, it successfully runs. However, when I run the same script with NCS2 connected, I get ncDeviceOpen error.
Attached is the error I am getting when I run python script. I've also added list of USB devices connected to my VM.
Any guidance/help is appreciated.
Hi @naufil
The NCSDK(v1 & v2) is _only_ compatible with the NCS1, which is why the hello_ncs did not work with your NCS2. The software kit that is compatible with both the NCS1 & NCS2 is OpenVINO. You can download the OpenVINO for Linux here .
Please let me know if you have any further questions!
Sahira
Understood.
Thanks @Sahira_at_Intel.
