def thread():
net = inference_engine.IENetwork(model=os.path.join(model_dir, '{}_{}.xml'.format(*shape)), weights=os.path.join(model_dir, '{}_{}.bin'.format(*shape)))
plugin = inference_engine.IEPlugin(device="CPU")
plugin.set_config({'CPU_BIND_THREAD':'NO', 'CPU_THREADS_NUM':'6', 'CPU_THROUGHPUT_STREAMS':'2'})
plugin.add_cpu_extension('libcpu_extension.so')
exec_net = plugin.load(net, 2)
exec_net.start_async(req_id, args)
exec_net.requests[req_id].wait()
When running thread function in two threads, wait in one thread blocks other thread's execution of request, tried creating plugin and net globally no difference
Since I have not tried it, I can not say cleary things.
Correctly the parameter is not zero?
exec_net.requests[req_id].wait(0)
it is exactly exec_net.requests[req_id].wait()
no parameter is given for wait function
It seems that it is in OpenVINO R5.
If I specify zero, It did not lock the thread.
I think a little wonder.
If u give zero for wait() it'll not block until the result is ready, so we have to give -1 or no param which blocks until the result is ready
